<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Deleting folders doesn&#x27;t work if more than one folder is selected.]]></title><description><![CDATA[<p dir="auto">Deleting folders doesn’t work if more than one folder is selected in a zip file.</p>
]]></description><link>https://forums.powerarchiver.com/topic/872/deleting-folders-doesn-t-work-if-more-than-one-folder-is-selected</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 02:16:35 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/872.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 May 2005 17:22:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Mon, 06 Jun 2005 20:56:43 GMT]]></title><description><![CDATA[<p dir="auto">Check this release out and see if it helps:<br />
<a href="http://www.powerarchiver.com/test/release/powarc925.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release/powarc925.exe</a></p>
<p dir="auto">This is 9.25 beta thats going to be published in a day or two.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/8571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8571</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 06 Jun 2005 20:56:43 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Fri, 03 Jun 2005 13:29:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/harry" aria-label="Profile: harry">@<bdi>harry</bdi></a>:</p>
<p dir="auto">I have tried some tests of this in PA 9.20.</p>
<p dir="auto">Using either Explorer or Classic view, the folder contents/files are deleted but the folders themselves are not.<br />
I think the problem is caused by folder names with ‘.’ characters as when I renamed the folders (before creating the zip file) then deleting folders worked.<br />
<a class="plugin-mentions-user plugin-mentions-a" href="/user/klumy" aria-label="Profile: klumy">@<bdi>klumy</bdi></a>:</p>
<p dir="auto">this works for me in the newest alpha 11</p>
<p dir="auto">So will be fixed in next version of PA (when it’s ready).</p>
<p dir="auto">BTW: Today I discovered that the folders I delete are only visible in explorer style view …… The classic view doesn’t show folders only.</p>
<p dir="auto">Classic view doesn’t show folders at all - it only shows the files with pathnames. I thought you were saying the path names were not shown.</p>
]]></description><link>https://forums.powerarchiver.com/post/8548</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8548</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Fri, 03 Jun 2005 13:29:01 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Fri, 03 Jun 2005 11:57:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tbgbe" aria-label="Profile: TBGBe">@<bdi>TBGBe</bdi></a>:</p>
<p dir="auto">Strange, from the snippet.txt they are not empty and so should be visible in Classic view (enable View details) - under “path” just like in the txt file.</p>
<p dir="auto">what I meant is that the explorer view show’s all subfolders of the current folder on top of the files. The classic view doesn’t show folders only.<br />
See my screenshot.gif from above post in the right pane, folders are from _spec to zlib, files are _clear.bat and below.</p>
<p dir="auto">It seems that PA is doing search and delete but doesn’t find anything for sqlite3.0.8/* sqlite3.1.6/*.<br />
Whole processing takes some minutes.</p>
<p dir="auto">While repeating this step I had another idea:<br />
Show a summery of how many files added/deleted/updated after processing in status bar.</p>
]]></description><link>https://forums.powerarchiver.com/post/8545</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8545</guid><dc:creator><![CDATA[harry]]></dc:creator><pubDate>Fri, 03 Jun 2005 11:57:56 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Wed, 01 Jun 2005 23:00:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/harry" aria-label="Profile: harry">@<bdi>harry</bdi></a>:</p>
<p dir="auto">Today I discovered that the folders I delete are only visible in explorer style view.</p>
]]></description><link>https://forums.powerarchiver.com/post/8539</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8539</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Wed, 01 Jun 2005 23:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Wed, 01 Jun 2005 21:09:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidsplash" aria-label="Profile: davidsplash">@<bdi>davidsplash</bdi></a>:</p>
<p dir="auto">what operating system how big is the archive what files names are used within the archive and how much size is free on your hard drive</p>
<p dir="auto">File size was about 170 MB, ca. 9000 files, frees space about 11 GB<br />
Im’m using PowerArchiver 9.2 on XP SP2.<br />
There was no message indicating any error. It just didn’t work.</p>
<p dir="auto">I attached part of the file list.<br />
And a screenshot what I did (sorry it’s german UI).</p>
<p dir="auto">After clicking delete - a dialog apears - select files - OK<br />
then there is some processing …<br />
and finally the folders are still there</p>
<p dir="auto">BTW: Today I discovered that the folders I delete are only visible in explorer style view.<br />
<a href="/uploads/_imported_attachments/attachment_p_3934_0_harry.zip">attachment_p_3934_0_harry.zip</a></p>
]]></description><link>https://forums.powerarchiver.com/post/8535</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8535</guid><dc:creator><![CDATA[harry]]></dc:creator><pubDate>Wed, 01 Jun 2005 21:09:13 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Tue, 31 May 2005 19:41:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/harry" aria-label="Profile: harry">@<bdi>harry</bdi></a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/8511</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8511</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Tue, 31 May 2005 19:41:44 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting folders doesn&#x27;t work if more than one folder is selected. on Tue, 31 May 2005 18:44:00 GMT]]></title><description><![CDATA[<p dir="auto">what operating system how big is the archive what files names are used within the archive and how much size is free on your hard drive</p>
]]></description><link>https://forums.powerarchiver.com/post/8508</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8508</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 31 May 2005 18:44:00 GMT</pubDate></item></channel></rss>
