<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Bug] Floating windows are docked after restart]]></title><description><![CDATA[<p dir="auto">Float the toolbar or the explorer tree and close PA. After restart the floated windows are docked.</p>
]]></description><link>https://forums.powerarchiver.com/topic/84/bug-floating-windows-are-docked-after-restart</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 19:11:13 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/84.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Jul 2004 14:16:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Sat, 31 Jul 2004 15:12:01 GMT]]></title><description><![CDATA[<p dir="auto">Thanks!</p>
<p dir="auto">The issues with docking toolbars and tree-folder panel will be fixed in next release!</p>
]]></description><link>https://forums.powerarchiver.com/post/5915</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5915</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sat, 31 Jul 2004 15:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Mon, 26 Jul 2004 15:50:26 GMT]]></title><description><![CDATA[<p dir="auto">thanks, we will check it out!</p>
]]></description><link>https://forums.powerarchiver.com/post/5791</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5791</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 26 Jul 2004 15:50:26 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Mon, 26 Jul 2004 15:31:27 GMT]]></title><description><![CDATA[<p dir="auto">ooh this bug is not nice! You must do something…</p>
]]></description><link>https://forums.powerarchiver.com/post/5781</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5781</guid><dc:creator><![CDATA[SpAwN oF T.D.F.]]></dc:creator><pubDate>Mon, 26 Jul 2004 15:31:27 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Sun, 25 Jul 2004 16:04:31 GMT]]></title><description><![CDATA[<p dir="auto">@postman:</p>
<p dir="auto">Drag the folder treeview above the listview and close PA. After restart the treeview covers nearly the whole width of PA window.</p>
<p dir="auto">Yes!<br />
And the treeview won’t be above the listview anymore, after restart…it will be on the left.</p>
]]></description><link>https://forums.powerarchiver.com/post/5750</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5750</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sun, 25 Jul 2004 16:04:31 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Sun, 25 Jul 2004 15:59:26 GMT]]></title><description><![CDATA[<p dir="auto">@postman:</p>
<p dir="auto">Dock the toolbar on left side and close PA. After restart the toolbar is shown between explorer view and explorer tree.</p>
<p dir="auto">Yes, you’re right! :eek:<br />
That’s bad, also after discovering that I like so much to have it on the left! :(</p>
<p dir="auto">The weird behaviour won’t happen if you dock the toolbar anywhere else…</p>
]]></description><link>https://forums.powerarchiver.com/post/5749</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5749</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sun, 25 Jul 2004 15:59:26 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Sun, 25 Jul 2004 14:23:19 GMT]]></title><description><![CDATA[<p dir="auto">Drag the folder treeview above the listview and close PA. After restart the treeview covers nearly the whole width of PA window.</p>
]]></description><link>https://forums.powerarchiver.com/post/5738</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5738</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 25 Jul 2004 14:23:19 GMT</pubDate></item><item><title><![CDATA[Reply to [Bug] Floating windows are docked after restart on Sun, 25 Jul 2004 14:19:11 GMT]]></title><description><![CDATA[<p dir="auto">Dock the toolbar on left side and close PA. After restart the toolbar is shown between explorer view and explorer tree.</p>
]]></description><link>https://forums.powerarchiver.com/post/5736</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5736</guid><dc:creator><![CDATA[[[global:guest]]]]></dc:creator><pubDate>Sun, 25 Jul 2004 14:19:11 GMT</pubDate></item></channel></rss>
