<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is the difference between….....]]></title><description><![CDATA[<p dir="auto">PACL and PA?</p>
<p dir="auto">Apart from the missing interface of cause. So in Theory everything done with PA can be done with PACL?</p>
]]></description><link>https://forums.powerarchiver.com/topic/8/what-is-the-difference-between</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 01:19:49 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/8.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Jul 2004 05:02:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is the difference between…..... on Sat, 17 Jul 2004 09:04:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iwod" aria-label="Profile: iwod">@<bdi>iwod</bdi></a>:</p>
<p dir="auto">It is separate tool really, everything is completly new/different than PA. PA has many more tools and options, while PACL has some features that are specific to command line… Both are advanced in their own right.</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/5516</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/5516</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 17 Jul 2004 09:04:30 GMT</pubDate></item></channel></rss>
