<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Conversion &quot;crawler&quot;]]></title><description><![CDATA[<p dir="auto">Hi</p>
<p dir="auto">Something I find missing from all the archivers I’ve looked at is a “crawler”, and it’s something I could really use. What I mean by this is a feature that will systematically crawl or spider through a specified folder and sub-folders and convert archives (e.g. zip) to another format (e.g. 7-zip) AND then compare the sizes of converted files and retain only the ones that are smaller.</p>
<p dir="auto">Both at home and at work I retain repositories of files (drivers, utilities, etc.) and I need to save space by keeping these files in the smallest archives possible. To manually convert hundreds of files is very time-consuming, and new files are being added all the time - a “crawler” feature would help me.</p>
<p dir="auto">Just a (hopeful) thought… :)</p>
]]></description><link>https://forums.powerarchiver.com/topic/695/conversion-crawler</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:56:01 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/695.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Apr 2005 07:00:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Conversion &quot;crawler&quot; on Tue, 12 Apr 2005 18:16:33 GMT]]></title><description><![CDATA[<p dir="auto">the computer had a bug in it virus which i just managed to get rid of all sorted now.</p>
<p dir="auto">anyone else whant to comment on this subject??</p>
]]></description><link>https://forums.powerarchiver.com/post/8024</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8024</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 12 Apr 2005 18:16:33 GMT</pubDate></item><item><title><![CDATA[Reply to Conversion &quot;crawler&quot; on Tue, 12 Apr 2005 17:02:28 GMT]]></title><description><![CDATA[<p dir="auto">David, could you press the Capslock button once again. It is very annoiing this way.</p>
<p dir="auto">:confused:</p>
]]></description><link>https://forums.powerarchiver.com/post/8022</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8022</guid><dc:creator><![CDATA[Jr heuwing]]></dc:creator><pubDate>Tue, 12 Apr 2005 17:02:28 GMT</pubDate></item><item><title><![CDATA[Reply to Conversion &quot;crawler&quot; on Tue, 12 Apr 2005 12:29:41 GMT]]></title><description><![CDATA[<p dir="auto">YOU CAN SELETECT IN THE CONVERT ARCHIVE SERVAL ARCHIVES AND COMPRESS THEM TO A DIFFERENT FORMAT.</p>
<p dir="auto">THE SMALLEST ARCHIVE FORMAT TO USE DEPENDS ON WAHT YOUR ARCHIVING AND IF YOU WANT TO KEEP CHANGING THE ARCHIVE AT ALL LIKE ADD FILES TO IT OR DELETE SOME FILES. nICE IDEA BUUT PRACTICALLY VERY DIFFICULT TO DO BUT CAN BE DONE. bUT IS IT WORTH IT</p>
]]></description><link>https://forums.powerarchiver.com/post/8020</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/8020</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 12 Apr 2005 12:29:41 GMT</pubDate></item></channel></rss>
