<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files]]></title><description><![CDATA[<p dir="auto">PA 21.00.18 running on Windows 7 64 bit.<br />
I made a big .PA file and thought I’d check it was made correctly with Menu / Actions / Test.<br />
Discovered:<br />
a) PA always issues a UAC prompt to do this!<br />
b) PA always says there are many errors in PA files.</p>
]]></description><link>https://forums.powerarchiver.com/topic/6420/pa-21-00-18-action-test-behaves-oddly-for-me-on-pa-files</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 20:28:58 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6420.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Oct 2022 18:58:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Mon, 26 Jun 2023 23:25:15 GMT]]></title><description><![CDATA[<p dir="auto">So far my testing shows that this seems to all be fixed in the new PA 22.00.09 from your main site.</p>
]]></description><link>https://forums.powerarchiver.com/post/38768</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38768</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Mon, 26 Jun 2023 23:25:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Tue, 16 May 2023 16:36:18 GMT]]></title><description><![CDATA[<p dir="auto">thanks very much <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a></p>
<p dir="auto">I see now, it occurs when testing 7z and PA archives via shell.<br />
Logged in and Ivan should fix it for the future update.</p>
<p dir="auto">thanks for your continued help!</p>
]]></description><link>https://forums.powerarchiver.com/post/38675</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38675</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 16 May 2023 16:36:18 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Mon, 15 May 2023 23:03:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> said in <a href="/post/38669">PA 21.00.18 Action / Test behaves oddly for me on .PA files</a>:</p>
<p dir="auto">hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a>,<br />
I’ve attempted to reproduce this with a sample archive but did not get the extraction of files to folder. Tried testing via shell and main PA.<br />
Does it happen to all archives or certain ones?</p>
<p dir="auto">All .PA archives I think.</p>
<p dir="auto">Could you please send a sample archive where you can reproduce to me at support at conexware dot com and I will take a look to reproduce it.  Certainly would like to fix it for the next update.</p>
<p dir="auto">Example Archive linked <a href="https://www.brian-gregory.me.uk/GDL/PABug1/vDOSPlus.pa" target="_blank" rel="noopener noreferrer nofollow ugc">here</a><br />
My PA settings linked <a href="https://www.brian-gregory.me.uk/GDL/PABug1/PASettings.reg" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
<p dir="auto">Right-click the PA file and choose “PowerArchiver” then on sub menu choose “Test”.<br />
The PA archive gets extracted to the directory containing it.<br />
I am running PA 22.00.08 on Windows 7 64 bit.</p>
]]></description><link>https://forums.powerarchiver.com/post/38674</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38674</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Mon, 15 May 2023 23:03:34 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Mon, 15 May 2023 16:53:17 GMT]]></title><description><![CDATA[<p dir="auto">hey <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a>,</p>
<p dir="auto">I’ve attempted to reproduce this with a sample archive but did not get the extraction of files to folder. Tried testing via shell and main PA.</p>
<p dir="auto">Does it happen to all archives or certain ones?</p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://forums.powerarchiver.com/post/38669</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38669</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 15 May 2023 16:53:17 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Fri, 12 May 2023 22:59:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> said in <a href="/post/38574">PA 21.00.18 Action / Test behaves oddly for me on .PA files</a>:</p>
<p dir="auto">Testing with the shell with 22.00.08 is a disaster.<br />
All the files get extracted to the current directory as if you had chosen extract here.<br />
Took me ages to clean up the mess, work out what was supposed to be where.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a>  <a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> Is this logged in too?</p>
<p dir="auto">How about releasing the first new fix this year?</p>
]]></description><link>https://forums.powerarchiver.com/post/38664</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38664</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Fri, 12 May 2023 22:59:46 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Sun, 05 Feb 2023 14:09:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> I’m seeing this with .pa test from Shell on 22.00.06. The archive tests OK, but every file in it has been extracted to the same folder as the archive.</p>
<p dir="auto">There seems to be no way from any settings or configuration to change this.</p>
]]></description><link>https://forums.powerarchiver.com/post/38575</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38575</guid><dc:creator><![CDATA[PA_Fan]]></dc:creator><pubDate>Sun, 05 Feb 2023 14:09:48 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Fri, 03 Feb 2023 20:25:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> said in <a href="/post/38497">PA 21.00.18 Action / Test behaves oddly for me on .PA files</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a></p>
<p dir="auto">Hey Brian,</p>
<p dir="auto">Thanks for the details! I’ve tested and confirmed that the UAC and error reporting occurs when testing from the main PowerArchiver interface, when testing through shell it seems fine.</p>
<p dir="auto">Logged in for fixing, many thanks again!</p>
<p dir="auto"><strong>Testing with the shell with 22.00.08 is a disaster.</strong><br />
]]></description><link>https://forums.powerarchiver.com/post/38574</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38574</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Fri, 03 Feb 2023 20:25:36 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Sat, 17 Dec 2022 00:38:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> <strong>Not</strong> fixed in PA 22.00.06.</p>
]]></description><link>https://forums.powerarchiver.com/post/38536</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38536</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Sat, 17 Dec 2022 00:38:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Thu, 17 Nov 2022 23:00:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/38510</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38510</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Thu, 17 Nov 2022 23:00:56 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Thu, 10 Nov 2022 17:46:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a></p>
]]></description><link>https://forums.powerarchiver.com/post/38497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38497</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 10 Nov 2022 17:46:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Tue, 08 Nov 2022 23:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> said in <a href="/post/38495">PA 21.00.18 Action / Test behaves oddly for me on .PA files</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> Is anybody at ConeXware reading this?</p>
<p dir="auto">Yeah,  thank you.  <a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> will test with latest internal release and let you know.</p>
]]></description><link>https://forums.powerarchiver.com/post/38496</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38496</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 08 Nov 2022 23:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to PA 21.00.18 Action &#x2F; Test behaves oddly for me on .PA files on Thu, 17 Nov 2022 23:00:16 GMT]]></title><description><![CDATA[<p dir="auto">Is anybody at ConeXware reading this?</p>
]]></description><link>https://forums.powerarchiver.com/post/38495</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38495</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Thu, 17 Nov 2022 23:00:16 GMT</pubDate></item></channel></rss>
