<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Configure Clouds Box]]></title><description><![CDATA[<p dir="auto">I was looking around in PA 2021 20.10.02 and discovered an issue. When I hit close to close out of this window, nothing happens. I have to go into taskman and kill the PA application.</p>
]]></description><link>https://forums.powerarchiver.com/topic/6338/configure-clouds-box</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 14:23:23 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6338.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 04 Jun 2021 16:50:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Configure Clouds Box on Fri, 11 Jun 2021 20:30:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> said in <a href="/post/38253">Configure Clouds Box</a>:</p>
<p dir="auto">thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a></p>
<p dir="auto">We have tried to reproduce this on a couple of computers and could not reproduce it.<br />
Could you provide a couple of reproduction steps for us to try here?<br />
And/Or screenshot and reg file to support at conexware dot com so that we can try that as well.<br />
Once we reproduce it, in any of those method, we can log it in for fixing.</p>
<p dir="auto">Will keep trying to reproduce it here as well.</p>
<p dir="auto">Thanks!</p>
<p dir="auto">Files sent.</p>
]]></description><link>https://forums.powerarchiver.com/post/38256</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38256</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Fri, 11 Jun 2021 20:30:41 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Clouds Box on Thu, 10 Jun 2021 03:50:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> I was able to reproduce this as well. Select the options tab, configure clouds. Now if I try to close the configure clouds menu without making any changes nothing happens. I have to open task manager to end the task to close PA.<br />
<img src="/assets/uploads/files/1623297026720-pa-20.10.02.jpg" alt="PA 20.10.02.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/38255</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38255</guid><dc:creator><![CDATA[skypx]]></dc:creator><pubDate>Thu, 10 Jun 2021 03:50:40 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Clouds Box on Wed, 09 Jun 2021 11:46:33 GMT]]></title><description><![CDATA[<p dir="auto">thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a></p>
]]></description><link>https://forums.powerarchiver.com/post/38253</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38253</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 09 Jun 2021 11:46:33 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Clouds Box on Tue, 08 Jun 2021 12:38:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> I can confirm this bug in Classic Toolbar with Classic Simple skin.</p>
]]></description><link>https://forums.powerarchiver.com/post/38252</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38252</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Tue, 08 Jun 2021 12:38:34 GMT</pubDate></item><item><title><![CDATA[Reply to Configure Clouds Box on Mon, 07 Jun 2021 13:26:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/bigdog" aria-label="Profile: bigdog">@<bdi>bigdog</bdi></a></p>
<p dir="auto">Which interface is this in?<br />
Have tried going to Clouds Tab&gt;Clouds Icon&gt;New Profile dropdown&gt;Configure Clouds and can close that configuration window successfully. Have tried both Close button and X.<br />
Is there an operation you do before the the close window will not close?<br />
We will try to reproduce it.</p>
]]></description><link>https://forums.powerarchiver.com/post/38251</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38251</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 07 Jun 2021 13:26:49 GMT</pubDate></item></channel></rss>
