<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Install with GPO - windows server 2019]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
I have some mistakes today with PowerArchiver Installation with GPO.<br />
I checked permissions of the share folder and I already installed some app from this.<br />
I have downloaded 32b and 64b it’s the same problem.<br />
App is on the install list of the GPO, but don’t install on the client. All app can be install but only powerachiver not. What the hell !</p>
<p dir="auto">So i tried :<br />
Checked : security of share folder --&gt; ok (install of other app ok!)<br />
RSOP checked --&gt; nothing special<br />
(obviously force GPO, multiple reboot)</p>
<p dir="auto">Can you help me please ?</p>
<p dir="auto"><img src="/assets/uploads/files/1621960716014-capture.jpg" alt="Capture.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/6334/install-with-gpo-windows-server-2019</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 12:34:14 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6334.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 May 2021 16:46:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Install with GPO - windows server 2019 on Tue, 22 Jun 2021 12:41:22 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Here are the latest versions to try:</p>
<p dir="auto"><a href="http://u.powerarchiver.com/pa2021/powarc201002x64.msi" target="_blank" rel="noopener noreferrer nofollow ugc">http://u.powerarchiver.com/pa2021/powarc201002x64.msi</a><br />
<a href="http://u.powerarchiver.com/pa2021/powarc201002x86.msi" target="_blank" rel="noopener noreferrer nofollow ugc">http://u.powerarchiver.com/pa2021/powarc201002x86.msi</a></p>
<p dir="auto">Please let us know if that works. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38270</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38270</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 22 Jun 2021 12:41:22 GMT</pubDate></item><item><title><![CDATA[Reply to Install with GPO - windows server 2019 on Mon, 21 Jun 2021 12:42:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ianiep" aria-label="Profile: ianiep">@<bdi>ianiep</bdi></a></p>
<p dir="auto">You can also try following MSIs with basic interface activated:<br />
<a href="http://u.powerarchiver.com/pa2021/powarc201002x64-nointerface.msi" target="_blank" rel="noopener noreferrer nofollow ugc">http://u.powerarchiver.com/pa2021/powarc201002x64-nointerface.msi</a><br />
<a href="http://u.powerarchiver.com/pa2021/powarc201002x86-nointerface.msi" target="_blank" rel="noopener noreferrer nofollow ugc">http://u.powerarchiver.com/pa2021/powarc201002x86-nointerface.msi</a></p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38269</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38269</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 21 Jun 2021 12:42:13 GMT</pubDate></item><item><title><![CDATA[Reply to Install with GPO - windows server 2019 on Mon, 21 Jun 2021 12:24:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ianiep" aria-label="Profile: ianiep">@<bdi>ianiep</bdi></a></p>
<p dir="auto">Hello, can you enable Windows Installer logging and check the log file to see what the issue is when GPO tries to run MSI?</p>
<p dir="auto">Here are the instructions:<br />
<a href="https://docs.microsoft.com/en-us/troubleshoot/windows-client/application-management/enable-windows-installer-logging" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.microsoft.com/en-us/troubleshoot/windows-client/application-management/enable-windows-installer-logging</a></p>
<p dir="auto">thank you!</p>
]]></description><link>https://forums.powerarchiver.com/post/38267</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38267</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 21 Jun 2021 12:24:29 GMT</pubDate></item><item><title><![CDATA[Reply to Install with GPO - windows server 2019 on Mon, 21 Jun 2021 10:38:04 GMT]]></title><description><![CDATA[<p dir="auto">Up !</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ianiep" aria-label="Profile: ianiep">@<bdi>ianiep</bdi></a> said in <a href="/post/38239">Install with GPO - windows server 2019</a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/38264</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38264</guid><dc:creator><![CDATA[ianiep]]></dc:creator><pubDate>Mon, 21 Jun 2021 10:38:04 GMT</pubDate></item></channel></rss>
