<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powerarchiver 2021  incorrectly extract tar.xz file]]></title><description><![CDATA[<p dir="auto">Configuration:<br />
Powerarchiver 2021 20.00.73<br />
Windows 10 Education  10.0.19042  Build 19042</p>
<p dir="auto">When extracting <a href="https://developer.arm.com/-/media/Files/downloads/gnu-a/10.2-2020.11/binrel/gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar.xz?revision=04032fd8-b142-4086-a50f-77bc843647a9&amp;la=en&amp;hash=CFE3143EC78AC9F3F98BD19911B901C129F5B833" target="_blank" rel="noopener noreferrer nofollow ugc">gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar.xz</a> , Powerarchiver wrongly thinks some .exe files have a length of zero:</p>
<p dir="auto"><img src="/assets/uploads/files/1614270796092-98773b3b-65c0-48fa-8cd4-d081b2e0adee-image.png" alt="98773b3b-65c0-48fa-8cd4-d081b2e0adee-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Once extracted:</p>
<pre><code>D:\Temp\Powerarchiver\gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf\bin&gt;dir *.exe
 Volume in drive D is DATA
 Volume Serial Number is 0E12-BCA2
 Directory of D:\Temp\Powerarchiver\gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf\bin
2020-11-20  07:10 PM         1,391,599 arm-none-linux-gnueabihf-addr2line.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-ar.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-as.exe
2020-11-20  07:41 PM         3,030,119 arm-none-linux-gnueabihf-c++.exe
2020-11-20  07:10 PM         1,389,293 arm-none-linux-gnueabihf-c++filt.exe
2020-11-20  07:41 PM         3,027,513 arm-none-linux-gnueabihf-cpp.exe
2020-11-20  07:10 PM         4,040,503 arm-none-linux-gnueabihf-dwp.exe
2020-11-20  07:10 PM           391,769 arm-none-linux-gnueabihf-elfedit.exe
2020-11-20  07:41 PM                 0 arm-none-linux-gnueabihf-g++.exe
2020-11-20  07:41 PM         3,026,926 arm-none-linux-gnueabihf-gcc-10.2.1.exe
2020-11-20  07:41 PM           609,607 arm-none-linux-gnueabihf-gcc-ar.exe
2020-11-20  07:41 PM           609,607 arm-none-linux-gnueabihf-gcc-nm.exe
2020-11-20  07:41 PM           609,607 arm-none-linux-gnueabihf-gcc-ranlib.exe
2020-11-20  07:41 PM                 0 arm-none-linux-gnueabihf-gcc.exe
2020-11-20  07:41 PM         2,165,533 arm-none-linux-gnueabihf-gcov-dump.exe
2020-11-20  07:41 PM         2,343,605 arm-none-linux-gnueabihf-gcov-tool.exe
2020-11-20  07:41 PM         2,450,233 arm-none-linux-gnueabihf-gcov.exe
2020-11-20  07:54 PM         9,605,899 arm-none-linux-gnueabihf-gdb.exe
2020-11-20  07:41 PM         3,028,997 arm-none-linux-gnueabihf-gfortran.exe
2020-11-20  07:10 PM         1,412,943 arm-none-linux-gnueabihf-gprof.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-ld.bfd.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-ld.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-ld.gold.exe
2020-11-20  07:41 PM        25,546,567 arm-none-linux-gnueabihf-lto-dump.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-nm.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-objcopy.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-objdump.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-ranlib.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-readelf.exe
2020-11-20  07:10 PM         1,393,083 arm-none-linux-gnueabihf-size.exe
2020-11-20  07:10 PM         1,392,464 arm-none-linux-gnueabihf-strings.exe
2020-11-20  07:10 PM                 0 arm-none-linux-gnueabihf-strip.exe
              32 File(s)     67,465,867 bytes
               0 Dir(s)  1,002,422,431,744 bytes free
</code></pre>
<p dir="auto">When the same archive is being extracted from a git bash session (after having installed git 2.30.1 for Windows 64 bit version from <a href="http://git-scm.com" target="_blank" rel="noopener noreferrer nofollow ugc">git-scm.com</a>), the .exe files are extracted as expected:</p>
<pre><code>xz -k -d gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar.xz
tar xf gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf.tar
cd gcc-arm-10.2-2020.11-mingw-w64-i686-arm-none-linux-gnueabihf/bin
ll *.exe
-rwxr-xr-x 1 User 197121  1391599 Nov 20 19:10 arm-none-linux-gnueabihf-addr2line.exe*
-rwxr-xr-x 2 User 197121  1421598 Nov 20 19:10 arm-none-linux-gnueabihf-ar.exe*
-rwxr-xr-x 2 User 197121  2028927 Nov 20 19:10 arm-none-linux-gnueabihf-as.exe*
-rwxr-xr-x 2 User 197121  3030119 Nov 20 19:41 arm-none-linux-gnueabihf-c++.exe*
-rwxr-xr-x 1 User 197121  1389293 Nov 20 19:10 arm-none-linux-gnueabihf-c++filt.exe*
-rwxr-xr-x 1 User 197121  3027513 Nov 20 19:41 arm-none-linux-gnueabihf-cpp.exe*
-rwxr-xr-x 1 User 197121  4040503 Nov 20 19:10 arm-none-linux-gnueabihf-dwp.exe*
-rwxr-xr-x 1 User 197121   391769 Nov 20 19:10 arm-none-linux-gnueabihf-elfedit.exe*
-rwxr-xr-x 2 User 197121  3030119 Nov 20 19:41 arm-none-linux-gnueabihf-g++.exe*
-rwxr-xr-x 2 User 197121  3026926 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-10.2.1.exe*
-rwxr-xr-x 1 User 197121   609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-ar.exe*
-rwxr-xr-x 1 User 197121   609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-nm.exe*
-rwxr-xr-x 1 User 197121   609607 Nov 20 19:41 arm-none-linux-gnueabihf-gcc-ranlib.exe*
-rwxr-xr-x 2 User 197121  3026926 Nov 20 19:41 arm-none-linux-gnueabihf-gcc.exe*
-rwxr-xr-x 1 User 197121  2165533 Nov 20 19:41 arm-none-linux-gnueabihf-gcov-dump.exe*
-rwxr-xr-x 1 User 197121  2343605 Nov 20 19:41 arm-none-linux-gnueabihf-gcov-tool.exe*
-rwxr-xr-x 1 User 197121  2450233 Nov 20 19:41 arm-none-linux-gnueabihf-gcov.exe*
-rwxr-xr-x 1 User 197121  9605899 Nov 20 19:54 arm-none-linux-gnueabihf-gdb.exe*
-rwxr-xr-x 1 User 197121  3028997 Nov 20 19:41 arm-none-linux-gnueabihf-gfortran.exe*
-rwxr-xr-x 1 User 197121  1412943 Nov 20 19:10 arm-none-linux-gnueabihf-gprof.exe*
-rwxr-xr-x 4 User 197121  2572182 Nov 20 19:10 arm-none-linux-gnueabihf-ld.bfd.exe*
-rwxr-xr-x 4 User 197121  2572182 Nov 20 19:10 arm-none-linux-gnueabihf-ld.exe*
-rwxr-xr-x 2 User 197121  4550029 Nov 20 19:10 arm-none-linux-gnueabihf-ld.gold.exe*
-rwxr-xr-x 1 User 197121 25546567 Nov 20 19:41 arm-none-linux-gnueabihf-lto-dump.exe*
-rwxr-xr-x 2 User 197121  1404945 Nov 20 19:10 arm-none-linux-gnueabihf-nm.exe*
-rwxr-xr-x 2 User 197121  1531656 Nov 20 19:10 arm-none-linux-gnueabihf-objcopy.exe*
-rwxr-xr-x 2 User 197121  1991350 Nov 20 19:10 arm-none-linux-gnueabihf-objdump.exe*
-rwxr-xr-x 2 User 197121  1421598 Nov 20 19:10 arm-none-linux-gnueabihf-ranlib.exe*
-rwxr-xr-x 2 User 197121  1163376 Nov 20 19:10 arm-none-linux-gnueabihf-readelf.exe*
-rwxr-xr-x 1 User 197121  1393083 Nov 20 19:10 arm-none-linux-gnueabihf-size.exe*
-rwxr-xr-x 1 User 197121  1392464 Nov 20 19:10 arm-none-linux-gnueabihf-strings.exe*
-rwxr-xr-x 2 User 197121  1531656 Nov 20 19:10 arm-none-linux-gnueabihf-strip.exe*
</code></pre>
<p dir="auto">The same archive file does extract properly under a native Linux Ubuntu 20.04 system, or under Windows 10 using the WSL2 Linux subsystem using xz and tar.</p>
]]></description><link>https://forums.powerarchiver.com/topic/6322/powerarchiver-2021-incorrectly-extract-tar-xz-file</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 16:10:30 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6322.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 25 Feb 2021 17:05:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Mon, 31 May 2021 12:36:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eperie" aria-label="Profile: eperie">@<bdi>eperie</bdi></a> Hello, new version has been released with fix for this issue. Can you please update and let us know? Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38242</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38242</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 31 May 2021 12:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Sat, 21 Aug 2021 03:04:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> Yes, the fix seems to be working, thank you.</p>
]]></description><link>https://forums.powerarchiver.com/post/38304</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38304</guid><dc:creator><![CDATA[eperie]]></dc:creator><pubDate>Sat, 21 Aug 2021 03:04:51 GMT</pubDate></item><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Mon, 31 May 2021 12:36:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eperie" aria-label="Profile: eperie">@<bdi>eperie</bdi></a> Hello, new version has been released with fix for this issue. Can you please update and let us know? Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38242</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38242</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 31 May 2021 12:36:41 GMT</pubDate></item><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Thu, 04 Mar 2021 17:44:05 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> ,</p>
<p dir="auto">You are welcome, and thank you for the feedback. Are you planning do update the current  thread at the time the issue will have been fixed ?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/38208</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38208</guid><dc:creator><![CDATA[eperie]]></dc:creator><pubDate>Thu, 04 Mar 2021 17:44:05 GMT</pubDate></item><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Fri, 05 Mar 2021 17:42:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> A lot of compressed tar files from linux/unix extract weirdly with PowerArchiver.<br />
I’ve never been able to figure out what’s going on so I’ve never reported it.<br />
For instance I often get messsages asking if I want to overwrite that suggest maybe some files are being extracted twice or that the paths are interpreted weirdly to mean several files end up in the same place.</p>
]]></description><link>https://forums.powerarchiver.com/post/38207</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38207</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Fri, 05 Mar 2021 17:42:36 GMT</pubDate></item><item><title><![CDATA[Reply to Powerarchiver 2021  incorrectly extract tar.xz file on Wed, 03 Mar 2021 15:54:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/eperie" aria-label="Profile: eperie">@<bdi>eperie</bdi></a></p>
<p dir="auto">We have reproduced the issue and it is logged in for fixing, many thanks for letting us know!</p>
]]></description><link>https://forums.powerarchiver.com/post/38206</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38206</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 03 Mar 2021 15:54:39 GMT</pubDate></item></channel></rss>
