<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Encryption Suite 2019]]></title><description><![CDATA[<p dir="auto">I purchased this product, however the software is not in usable condition.</p>
<p dir="auto">I cannot view the buttons, and what they are for.</p>
<p dir="auto">There has been no update so far</p>
<p dir="auto">When I try to do 8192 bits RSA compression the process gets stuck for me for long time.</p>
<p dir="auto">When I try RSA 4096, it does not show any error, but later, I cannot find any key created, nor am I able to generate any more keys, because the dialog box gets hidden.</p>
<p dir="auto"><img src="/assets/uploads/files/1613759607140-es-generate.png" alt="ES Generate.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I even tried to change the Color Scheme, it did not work.</p>
<p dir="auto">When I try to open the Manage PGP keys option, I can still generate new ECDSA keys, but cannot for RSA.<br />
However, in this menu as well, I cannot export because of visual UI bug.</p>
<p dir="auto"><img src="/assets/uploads/files/1613759631222-es-export.png" alt="ES Export.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Will there be any further development on this?</p>
]]></description><link>https://forums.powerarchiver.com/topic/6320/encryption-suite-2019</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 05:38:06 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6320.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Feb 2021 18:34:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Encryption Suite 2019 on Thu, 23 Mar 2023 12:46:57 GMT]]></title><description><![CDATA[<p dir="auto">I finally found the forum my friends told me about. I’m glad to join you.</p>
]]></description><link>https://forums.powerarchiver.com/post/38616</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38616</guid><dc:creator><![CDATA[SachinKumar]]></dc:creator><pubDate>Thu, 23 Mar 2023 12:46:57 GMT</pubDate></item><item><title><![CDATA[Reply to Encryption Suite 2019 on Sun, 12 Mar 2023 16:38:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">I have here the similar problems like godlydevils.<br />
After I create a new key and leave the openPgP Keys section and come back, then the created key has gone. So the key is not stored permanently.<br />
I can create all kinds of keys without any Problems, even 8192 RSA, but the keys are not stored permanently. So I haven’t problems with the key creation, but I have problems that the keys are never stored in the program.<br />
When I want to use the function export, then I have the UI problems too like godlydevils in his second image. I can’t read anything. I can only see what happens, after I select one of the 4 option.  I tested all 3 color options. All the same. It makes no difference.</p>
<p dir="auto">I tried the key import function, but here I have the same problem. I can import a key, but when I leave the key section and come back, the key isn’t here anymore.</p>
<p dir="auto">My language is german, so I wanted to use the program in german language too.<br />
When I use the german language the area for the secure Storage is still in english as you can see in this image. The main area and all sub areas from the secure Storage is in english, but I selected in the options german language.<br />
<img src="/assets/uploads/files/1678636925123-ecs-bild-2.jpg" alt="ECS Bild 2.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">What can I do now? Is there a patch or fix so I can use the program the way it’s intended?</p>
<p dir="auto">I use windows 10 Pro x64. The Version is Version 22H2 (Build 19045.2673).</p>
<p dir="auto">Best regards<br />
MDuss</p>
<p dir="auto">Edit: I have know found something interesting. When I use powerarchiver to import an openpgp Key, then the key is also in Encryption Suite. And know the key will not disappear. So I can use the key within the Encryption Suite. When I try to delete the key from Encryption Suite, then the key seems to be deleted. But when I leave the key section and come back, then the keys I back again. So I can’t delete the key from Encryption Suite. When I delete the key over powerarchiver, then the key is also deleted in Encryption Suite.</p>
<p dir="auto">It seems that powerarchiver and Encryption Suite used the same database for the keys, but Encryption Suite has no possibility to write to the database. But I don’t know if this problem occurs if Encryption Suite is installed without powerarchiver.</p>
<p dir="auto">For me I have both programs installed. It would be interesting to know if godlydevils or girl libra have both programs installed too.</p>
]]></description><link>https://forums.powerarchiver.com/post/38613</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38613</guid><dc:creator><![CDATA[MDuss]]></dc:creator><pubDate>Sun, 12 Mar 2023 16:38:25 GMT</pubDate></item><item><title><![CDATA[Reply to Encryption Suite 2019 on Mon, 27 Feb 2023 17:23:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> said in <a href="/post/38192">Encryption Suite 2019</a>:</p>
<p dir="auto">thanks for the details <a class="plugin-mentions-user plugin-mentions-a" href="/user/godlydevils" aria-label="Profile: godlydevils">@<bdi>godlydevils</bdi></a></p>
<p dir="auto">We are in the process of working on a major upgrade to Encryption Suite PRO.<br />
Among some new features, it will have a new UI as well.<br />
We have the very first versions in at the moment, I was able to reproduce the AV error as well and that has been logged in for fixing.</p>
<p dir="auto">Once there is a usable version of ES PRO 2022 for checking out, I will send it over to you to check out. Sorting out current bugs and working on UI at the moment.</p>
<p dir="auto">Thanks!</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a><br />
Have you shared the new version link or not?<br />
I want the link if it’s done.</p>
]]></description><link>https://forums.powerarchiver.com/post/38590</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38590</guid><dc:creator><![CDATA[girl libra]]></dc:creator><pubDate>Mon, 27 Feb 2023 17:23:20 GMT</pubDate></item><item><title><![CDATA[Reply to Encryption Suite 2019 on Mon, 27 Feb 2023 17:19:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a><br />
]]></description><link>https://forums.powerarchiver.com/post/38589</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38589</guid><dc:creator><![CDATA[girl libra]]></dc:creator><pubDate>Mon, 27 Feb 2023 17:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to Encryption Suite 2019 on Mon, 22 Feb 2021 23:52:05 GMT]]></title><description><![CDATA[<p dir="auto">thanks for the details <a class="plugin-mentions-user plugin-mentions-a" href="/user/godlydevils" aria-label="Profile: godlydevils">@<bdi>godlydevils</bdi></a></p>
]]></description><link>https://forums.powerarchiver.com/post/38192</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38192</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 22 Feb 2021 23:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to Encryption Suite 2019 on Fri, 19 Feb 2021 18:37:26 GMT]]></title><description><![CDATA[<p dir="auto">I also tried to generate small RSA 2048 bit keys.</p>
<p dir="auto">Progress seemed to have successfully completed.</p>
<p dir="auto">However, later if I open manage PGP keys, I now encounter this error, always, now, I cannot click any buttons or even empty space in that dialog box</p>
<p dir="auto"><img src="/assets/uploads/files/1613759842799-image_2021-02-20_000722.png" alt="image_2021-02-20_000722.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/38186</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38186</guid><dc:creator><![CDATA[godlydevils]]></dc:creator><pubDate>Fri, 19 Feb 2021 18:37:26 GMT</pubDate></item></channel></rss>
