<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ZIPX: Add support for packing JPEG with specialized algorithm]]></title><description><![CDATA[<p dir="auto">Hello!<br />
I know I have been asking for this feature some time ago, but as nothing has changed let me ask again:<br />
The ZIPX-format offers an algorithm, that compresses JPEG-files by about 20-30%. Please add compression (packing) support for this in ZIPX-archives to Powerarchiver. Extraction of JPEGs packed into ZIPX by this algorithm is already supported by Powerarchiver for a long time, so it should not be difficult? Or is it a licensing problem?<br />
Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/topic/6319/zipx-add-support-for-packing-jpeg-with-specialized-algorithm</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 22:14:35 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6319.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Feb 2021 18:01:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ZIPX: Add support for packing JPEG with specialized algorithm on Sun, 07 Mar 2021 09:46:40 GMT]]></title><description><![CDATA[<p dir="auto">I would be perfectly happy, if PowerArchiver offered me a portable solution with FULL (i.e. also compression and not only decompression) support of  all methods offered by ZIPX.<br />
Once again: as unpacking is already implemented for all ZIPX-methods it should be possible to also add packing?! Or is it really a licensing (WinZIP patents) or marketing (further pushing PA-format) issue?<br />
While I think it’s good to develop and push an own technologically advanced format like PA, there is also a need for compatibility, interoperability and exchange with others (using other software) . And ZIPX is currently more common because of the great old name and the wiedspread use of its originating software, WinZIP.</p>
]]></description><link>https://forums.powerarchiver.com/post/38209</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38209</guid><dc:creator><![CDATA[a.borque]]></dc:creator><pubDate>Sun, 07 Mar 2021 09:46:40 GMT</pubDate></item><item><title><![CDATA[Reply to ZIPX: Add support for packing JPEG with specialized algorithm on Tue, 02 Mar 2021 21:13:26 GMT]]></title><description><![CDATA[<p dir="auto">Good evening,<br />
I am also in favor of implementing the decoder for JPG files in Zipx format, because this would really increase the compression ratio! The best would be that for as many file types as possible, the appropriate decoders would be implemented. Also Precomp would be another idea, the decoders and Precomp should be usable in .pa format as well as Zipx format, that would be great! You should team up with the guys from Encode, the guys are fit, what compression algorithms are concerned, I don’t want to mention any competing products, but there are programs, which with the right settings and the corresponding decoders and Precomp, achieve much better compression rates than Powerarchiver or your . zipx format, also I am disappointed with Powerarchiver and if after my 3 year Toolbox license nothing improves (especially what all the bugs in the program concern, PowerArchiver is there for over 15 years and “feels” extremely unfinished and after alpha or beta), I will not renew the license and look for alternatives (Which are often even free).</p>
]]></description><link>https://forums.powerarchiver.com/post/38204</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38204</guid><dc:creator><![CDATA[Konglomat]]></dc:creator><pubDate>Tue, 02 Mar 2021 21:13:26 GMT</pubDate></item></channel></rss>
