<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Elevation of UAC in Mounting Images]]></title><description><![CDATA[<p dir="auto">I love this, only there is one problem. The UAC elevation feature does not extend to Mount Image option in the add-on software PA provided. It is most annoying whenever I am on highest UAC settings and I mount an ISO, every time I open and create a virtual drive UAC appears. I also do not want to completely disable UAC.</p>
<p dir="auto">Is adding UAC elevation for mount image feature possible?</p>
]]></description><link>https://forums.powerarchiver.com/topic/6303/elevation-of-uac-in-mounting-images</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 18:44:56 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6303.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Jan 2021 13:21:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Elevation of UAC in Mounting Images on Wed, 27 Jan 2021 09:51:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: mili">@<bdi>mili</bdi></a> I launched it through PA’s interface, in “burn” section.</p>
<p dir="auto">Also, when trying to use PA’s “dismount” feature through Context Menu, nothing happened. I am forced to go to PA and dismount the disk myself. I am on strictest option of UAC (i.e. top of slidebar)</p>
]]></description><link>https://forums.powerarchiver.com/post/38141</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38141</guid><dc:creator><![CDATA[falco99]]></dc:creator><pubDate>Wed, 27 Jan 2021 09:51:13 GMT</pubDate></item><item><title><![CDATA[Reply to Elevation of UAC in Mounting Images on Tue, 26 Jan 2021 12:27:07 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/falco99" aria-label="Profile: falco99">@<bdi>falco99</bdi></a><br />
How are you mounting the images and from which location?<br />
Attempted to reproduce this but the UAC did not appear when adding images. Only appears when starting VD.<br />
Please let us know how you’re mounting the VD’s and we’ll try to reproduce using the same method.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38135</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38135</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 26 Jan 2021 12:27:07 GMT</pubDate></item></channel></rss>
