<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Include Virtual Drive as standalone in the installer]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.</p>
<p dir="auto">I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://forums.powerarchiver.com/topic/6286/include-virtual-drive-as-standalone-in-the-installer</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 13:18:43 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6286.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Dec 2020 23:15:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Include Virtual Drive as standalone in the installer on Mon, 14 Dec 2020 17:21:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi.</p>
<p dir="auto">Thank you very much for your support!</p>
<p dir="auto">I do have a question: if a new version of Virtual Drive gets updated, is there a stable link where i can always find the latest update for this tool?</p>
<p dir="auto">For now i just use trial and error and base my download from the online update check, infer the new file name from the updater if a new version is available, then modify a bookmark link i found according to the latest version, in order to fetch the offline installer for PA virtual drive. Or ask here regularly, which doesn’t seem too pleasant to do repeatedly if a new version is released.</p>
]]></description><link>https://forums.powerarchiver.com/post/38080</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38080</guid><dc:creator><![CDATA[2Flo]]></dc:creator><pubDate>Mon, 14 Dec 2020 17:21:17 GMT</pubDate></item><item><title><![CDATA[Reply to Include Virtual Drive as standalone in the installer on Mon, 14 Dec 2020 16:10:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/2flo" aria-label="Profile: 2Flo">@<bdi>2Flo</bdi></a><br />
At times, we have to update VD separately from PowerArchiver and it works best to keep the installations separate.<br />
We can always provide you with the link to the latest PAVD installation, <a href="http://u.powerarchiver.com/pa2021/pavd24006.exe" target="_blank" rel="noopener noreferrer nofollow ugc">here is the link to the current latest PAVD installation.</a><br />
Hope that works.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/38079</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/38079</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 14 Dec 2020 16:10:48 GMT</pubDate></item></channel></rss>
