<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bug report]]></title><description><![CDATA[<p dir="auto">I have power archiver toolbox version. when i right click and select compress to <a href="http://xxxx.pa" target="_blank" rel="noopener noreferrer nofollow ugc">xxxx.pa</a> then i show buy windows despite of toolbox version.</p>
<p dir="auto"><img src="https://i.imgur.com/Tiud0TK.png" alt="Imgur" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="https://i.imgur.com/nHlyYuc.png" alt="Imgur" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/6181/bug-report</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 06:29:48 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6181.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Jun 2019 16:48:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bug report on Fri, 21 Jun 2019 12:25:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> ok got the my other email address that have toolbox version with pa support but i think that is not lifetime upgradable license because i have not found any 2019 version resend button.</p>
]]></description><link>https://forums.powerarchiver.com/post/37506</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37506</guid><dc:creator><![CDATA[dharmang19101]]></dc:creator><pubDate>Fri, 21 Jun 2019 12:25:23 GMT</pubDate></item><item><title><![CDATA[Reply to Bug report on Fri, 21 Jun 2019 11:07:28 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/dharmang19101" aria-label="Profile: dharmang19101">@<bdi>dharmang19101</bdi></a><br />
We’ll gladly assist. I see your support ticket and I’ll reply there as it’s more convenient.<br />
thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/37504</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37504</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Fri, 21 Jun 2019 11:07:28 GMT</pubDate></item><item><title><![CDATA[Reply to Bug report on Fri, 21 Jun 2019 05:38:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> I have not got any email yet, but i have my login details so i have pressed resend code in power archiver 2019 version and i got email for that. I have entered that code for registration but still got that error message. Can you help me in regard?</p>
]]></description><link>https://forums.powerarchiver.com/post/37503</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37503</guid><dc:creator><![CDATA[dharmang19101]]></dc:creator><pubDate>Fri, 21 Jun 2019 05:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to Bug report on Wed, 19 Jun 2019 13:36:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guido" aria-label="Profile: guido">@<bdi>guido</bdi></a> said in <a href="/post/37498">Bug report</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> maybe edit out his email?</p>
<p dir="auto">fixed, thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/37499</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37499</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 19 Jun 2019 13:36:45 GMT</pubDate></item><item><title><![CDATA[Reply to Bug report on Wed, 19 Jun 2019 13:30:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> maybe edit out his email?</p>
]]></description><link>https://forums.powerarchiver.com/post/37498</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37498</guid><dc:creator><![CDATA[guido]]></dc:creator><pubDate>Wed, 19 Jun 2019 13:30:13 GMT</pubDate></item><item><title><![CDATA[Reply to Bug report on Wed, 19 Jun 2019 13:36:11 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/dharmang19101" aria-label="Profile: dharmang19101">@<bdi>dharmang19101</bdi></a></p>
<p dir="auto">PowerArchiver Toolbox without the Advanced Codec Pack will not provide the .PA format.<br />
I’ve checked your accounts and there are a few. Most of them do not include the Advanced Codec Pack but one does. It is the license that you won by being the GiveAwayOfTheDay idea winner. There, you won the Toolbox version with the Advanced Codec Pack and if you upgrade to 2019 from that license, the Advanced Codec Pack will allow you to use the .PA format.</p>
<p dir="auto">That license is under the email address which was used for the GOTD idea contest and I have sent you your account login information there so that you may log in and retrieve the 2019 registration.</p>
]]></description><link>https://forums.powerarchiver.com/post/37497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37497</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 19 Jun 2019 13:36:11 GMT</pubDate></item></channel></rss>
