<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Outdated SFX-Text &amp; Design]]></title><description><![CDATA[<p dir="auto">The SFX file still shows old informations and I really think it should be updated generally (Fonts, Design etc.)</p>
<p dir="auto"><img src="/assets/uploads/files/1553678152609-unbenannt-1.jpg" alt="Unbenannt 1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/6152/outdated-sfx-text-design</link><generator>RSS for Node</generator><lastBuildDate>Mon, 13 Jul 2026 09:00:51 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6152.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Mar 2019 09:18:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Outdated SFX-Text &amp; Design on Fri, 12 Apr 2019 15:45:09 GMT]]></title><description><![CDATA[<p dir="auto">Should appear fine now in version .43<br />
<a href="https://powerarchiver.cachefly.net/2019/powarc190043.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://powerarchiver.cachefly.net/2019/powarc190043.exe</a></p>
<p dir="auto">thanks for the help <a class="plugin-mentions-user plugin-mentions-a" href="/user/merowinger" aria-label="Profile: Merowinger">@<bdi>Merowinger</bdi></a></p>
]]></description><link>https://forums.powerarchiver.com/post/37378</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37378</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Fri, 12 Apr 2019 15:45:09 GMT</pubDate></item><item><title><![CDATA[Reply to Outdated SFX-Text &amp; Design on Wed, 27 Mar 2019 18:38:14 GMT]]></title><description><![CDATA[<p dir="auto">great, many thanks for the help. Adding info to the log</p>
]]></description><link>https://forums.powerarchiver.com/post/37344</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37344</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 27 Mar 2019 18:38:14 GMT</pubDate></item><item><title><![CDATA[Reply to Outdated SFX-Text &amp; Design on Wed, 27 Mar 2019 18:25:54 GMT]]></title><description><![CDATA[<p dir="auto">Yes, it’s from the “Overwrite”-Screen. In the english text it shows Power Archiver 2017, btw.</p>
]]></description><link>https://forums.powerarchiver.com/post/37343</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37343</guid><dc:creator><![CDATA[Merowinger]]></dc:creator><pubDate>Wed, 27 Mar 2019 18:25:54 GMT</pubDate></item><item><title><![CDATA[Reply to Outdated SFX-Text &amp; Design on Wed, 27 Mar 2019 16:01:42 GMT]]></title><description><![CDATA[<p dir="auto">hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/merowinger" aria-label="Profile: Merowinger">@<bdi>Merowinger</bdi></a><br />
thanks for the info. I have also found that the About screen shows PA 2016 and we will update that.<br />
The screenshot you send, is that from the Overwrite screen?<br />
I’d like to log that screen in as well for fixing/updating.</p>
]]></description><link>https://forums.powerarchiver.com/post/37342</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37342</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 27 Mar 2019 16:01:42 GMT</pubDate></item></channel></rss>
