<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unwarranted Right Click Menu Entries By Powerarchiver]]></title><description><![CDATA[<p dir="auto">I never gave Power Archiver permission to make any entries in the right click menu.  I think it is called “context menu.”</p>
<p dir="auto">Options during installation:</p>
<p dir="auto"><a href="http://www.general-cathexis.com/images/PowerArchiverConfigurationOptions.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.general-cathexis.com/images/PowerArchiverConfigurationOptions.png</a></p>
<p dir="auto"><a href="http://www.general-cathexis.com/images/PowerArchiverConfigurationOptions2.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.general-cathexis.com/images/PowerArchiverConfigurationOptions2.png</a></p>
<p dir="auto">Unwanted Entries in Right Click Menu:</p>
<p dir="auto"><a href="http://www.general-cathexis.com/images/PowerArchiverContextMenu.png" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.general-cathexis.com/images/PowerArchiverContextMenu.png</a></p>
<p dir="auto">How do I completely remove Power Archiver from all context menus?</p>
<p dir="auto">In case you are wondering, “Why?”  The operation that I use 99.99% of the time is Delete, which is the last item in the context menu.  Power Archiver and anything else in the context menu requires that I move my mouse cursor an unnecessarily long distance to delete a file.  In fact, I find such unwanted obstacles in my context menu so obnoxious, that I will uninstall a program to get rid of them.</p>
<p dir="auto">Most software developers must have a overly high opinion of their software to install stuff the context menu without the user’s permission.  The fact is, “Less is more.”</p>
<p dir="auto">I will uninstall Power Archiver, if this problem is not resolved.</p>
]]></description><link>https://forums.powerarchiver.com/topic/6128/unwarranted-right-click-menu-entries-by-powerarchiver</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 13:33:58 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6128.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Feb 2019 18:34:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unwarranted Right Click Menu Entries By Powerarchiver on Wed, 20 Feb 2019 18:41:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/aruzinsky" aria-label="Profile: aruzinsky">@<bdi>aruzinsky</bdi></a><br />
You can turn off shell extensions/context menu by going to the Configuration&gt;Shell extensions section and unchecking the “Use Explorer Shell Extensions” option.<br />
Click OK on the bottom of the Configuration window and the right click Options should not appear anymore.<br />
We have tested and confirmed this in the latest 2019 version.<br />
Please let us know if that helps. Thanks!</p>
<p dir="auto"><img src="/assets/uploads/files/1550687967484-use-shell.jpg" alt="Use Shell.JPG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/37227</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37227</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:41:25 GMT</pubDate></item><item><title><![CDATA[Reply to Unwarranted Right Click Menu Entries By Powerarchiver on Wed, 20 Feb 2019 19:11:49 GMT]]></title><description><![CDATA[<p dir="auto">glad it worked out <a class="plugin-mentions-user plugin-mentions-a" href="/user/aruzinsky" aria-label="Profile: aruzinsky">@<bdi>aruzinsky</bdi></a><br />
please write whenever we can be of assistance.</p>
]]></description><link>https://forums.powerarchiver.com/post/37231</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37231</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 20 Feb 2019 19:11:49 GMT</pubDate></item><item><title><![CDATA[Reply to Unwarranted Right Click Menu Entries By Powerarchiver on Wed, 20 Feb 2019 18:49:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> Thank you.  It worked.</p>
]]></description><link>https://forums.powerarchiver.com/post/37230</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37230</guid><dc:creator><![CDATA[aruzinsky]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:49:49 GMT</pubDate></item><item><title><![CDATA[Reply to Unwarranted Right Click Menu Entries By Powerarchiver on Wed, 20 Feb 2019 18:41:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/aruzinsky" aria-label="Profile: aruzinsky">@<bdi>aruzinsky</bdi></a><br />
]]></description><link>https://forums.powerarchiver.com/post/37227</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37227</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 20 Feb 2019 18:41:25 GMT</pubDate></item></channel></rss>
