<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Drag&amp;Drop 0 bytes files!]]></title><description><![CDATA[<p dir="auto">Drag&amp;Drop doesn’t work as expected, always drop 0 bytes files, if I try to Drag&amp;Drop again and ansher YES for subscribe existen files, works.</p>
<p dir="auto">It’s weird and counter-productive, Besides messing up a lot in momentes of rush time.</p>
<ul>
<li>I already tried other destination folders like %temp%, and of course… running the application as administrator.</li>
<li>Uninstalled with “Revo Uninstaller”, and try all over again… and nothing.</li>
<li>The problems appears on all the kinds os extensions (PA,ZIP 7z…).</li>
</ul>
<p dir="auto">I’m usinging the last version of PowerArchiver 2019 19.00.18</p>
]]></description><link>https://forums.powerarchiver.com/topic/6095/drag-drop-0-bytes-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 14:09:17 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6095.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 23 Jan 2019 23:22:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Mon, 28 Jan 2019 22:12:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/italofurquim" aria-label="Profile: ItaloFurquim">@<bdi>ItaloFurquim</bdi></a> said in <a href="/post/37079">Drag&amp;Drop 0 bytes files!</a>:</p>
<p dir="auto">Unfortunately the problem persists</p>
<p dir="auto">Please check this new build:</p>
<p dir="auto">Download:<br />
<a href="https://powerarchiver.cachefly.net/2019/powarc190023.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://powerarchiver.cachefly.net/2019/powarc190023.exe</a></p>
<p dir="auto">thank you!</p>
]]></description><link>https://forums.powerarchiver.com/post/37090</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37090</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 28 Jan 2019 22:12:03 GMT</pubDate></item><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Wed, 30 Jan 2019 00:56:40 GMT]]></title><description><![CDATA[<p dir="auto">:thumbs_up_light_skin_tone: Working fine… It’s solved, thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/37102</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37102</guid><dc:creator><![CDATA[ItaloFurquim]]></dc:creator><pubDate>Wed, 30 Jan 2019 00:56:40 GMT</pubDate></item><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Mon, 28 Jan 2019 22:12:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/italofurquim" aria-label="Profile: ItaloFurquim">@<bdi>ItaloFurquim</bdi></a> said in <a href="/post/37079">Drag&amp;Drop 0 bytes files!</a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/37090</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37090</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 28 Jan 2019 22:12:03 GMT</pubDate></item><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Thu, 24 Jan 2019 16:41:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/italofurquim" aria-label="Profile: ItaloFurquim">@<bdi>ItaloFurquim</bdi></a> said in <a href="/post/37079">Drag&amp;Drop 0 bytes files!</a>:</p>
<p dir="auto">thank you, we will take a look for next build and let you know when it is fixed.</p>
]]></description><link>https://forums.powerarchiver.com/post/37081</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37081</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 24 Jan 2019 16:41:32 GMT</pubDate></item><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Thu, 24 Jan 2019 14:34:17 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately the problem persists</p>
]]></description><link>https://forums.powerarchiver.com/post/37079</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37079</guid><dc:creator><![CDATA[ItaloFurquim]]></dc:creator><pubDate>Thu, 24 Jan 2019 14:34:17 GMT</pubDate></item><item><title><![CDATA[Reply to Drag&amp;Drop 0 bytes files! on Wed, 23 Jan 2019 23:38:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/italofurquim" aria-label="Profile: ItaloFurquim">@<bdi>ItaloFurquim</bdi></a> said in <a href="/post/37072">Drag&amp;Drop 0 bytes files!</a>:</p>
<ul>
</ul>
<p dir="auto">Please try latest internal build:<br />
<a href="https://powerarchiver.cachefly.net/2019/powarc190019.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://powerarchiver.cachefly.net/2019/powarc190019.exe</a></p>
<p dir="auto">It should be fixed in this release.</p>
]]></description><link>https://forums.powerarchiver.com/post/37073</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37073</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 23 Jan 2019 23:38:23 GMT</pubDate></item></channel></rss>
