<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[hang when using the Test function with 7z archives]]></title><description><![CDATA[<p dir="auto">I seem to have found a bug :o</p>
<p dir="auto">I’ve tested with several different files, and PowerArchiver always hangs indefinitely when the Test function is used with a 7zip type archive (at least files created with this version of PowerArchiver, I did not have files created with other software to test with). It just does not work, and the process needs to be manually terminated. With other types of archive like zip the Test function does work properly, the problem is only with 7z files.</p>
<p dir="auto">Windows 8.1 64-bit, latest PowerArchiver version in x64</p>
]]></description><link>https://forums.powerarchiver.com/topic/6000/hang-when-using-the-test-function-with-7z-archives</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Apr 2026 03:11:39 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/6000.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 11 Aug 2018 11:14:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to hang when using the Test function with 7z archives on Wed, 21 Aug 2019 11:32:09 GMT]]></title><description><![CDATA[<p dir="auto">finally got it reproduced and logged in, thanks all!</p>
]]></description><link>https://forums.powerarchiver.com/post/37560</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37560</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 21 Aug 2019 11:32:09 GMT</pubDate></item><item><title><![CDATA[Reply to hang when using the Test function with 7z archives on Sun, 18 Aug 2019 12:01:04 GMT]]></title><description><![CDATA[<p dir="auto">Same here.<br />
Confirmed with 19.00.51.</p>
]]></description><link>https://forums.powerarchiver.com/post/37554</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37554</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Sun, 18 Aug 2019 12:01:04 GMT</pubDate></item><item><title><![CDATA[Reply to hang when using the Test function with 7z archives on Sun, 18 Aug 2019 02:53:05 GMT]]></title><description><![CDATA[<p dir="auto">I just noticed by accident that this bug still seems to exist in version 19.00.50 :o I had forgotten about it since I use the Test function so randomly. Thought it would be worth mentioning here. Keep up the good work, guys. :)</p>
]]></description><link>https://forums.powerarchiver.com/post/37552</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/37552</guid><dc:creator><![CDATA[Big_Boss]]></dc:creator><pubDate>Sun, 18 Aug 2019 02:53:05 GMT</pubDate></item><item><title><![CDATA[Reply to hang when using the Test function with 7z archives on Sat, 11 Aug 2018 12:28:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/big_boss" aria-label="Profile: Big_Boss">@<bdi>Big_Boss</bdi></a> said in <a href="/post/36640">hang when using the Test function with 7z archives</a>:</p>
<p dir="auto">Thanks for the report, <a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> will write it up</p>
]]></description><link>https://forums.powerarchiver.com/post/36645</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36645</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 11 Aug 2018 12:28:03 GMT</pubDate></item></channel></rss>
