<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PACompXX problem with file name syntax]]></title><description><![CDATA[<p dir="auto">Hi,<br />
there’s a problem with PAComp and file names with a leading ".\ ".<br />
That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip.</p>
<p dir="auto"><img src="/assets/uploads/files/1524826662978-pacomp.png" alt="0_1524826660985_pacomp.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The first command reports “All OK”, but test.7z is not created.<br />
The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”.<br />
Only the third command (without ".\ ") works as expected.</p>
<p dir="auto">The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).</p>
]]></description><link>https://forums.powerarchiver.com/topic/5964/pacompxx-problem-with-file-name-syntax</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 07:13:14 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5964.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 27 Apr 2018 11:06:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PACompXX problem with file name syntax on Wed, 02 May 2018 23:09:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigmike" aria-label="Profile: bigmike">@<bdi>bigmike</bdi></a> we will check it out, thank you.</p>
]]></description><link>https://forums.powerarchiver.com/post/36433</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36433</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 02 May 2018 23:09:20 GMT</pubDate></item></channel></rss>
