<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Configuration bug in relelase version of 2018]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Run the program with the default Modern Toolbar selected, then go to the Configuation Options, change a file extension associated with the program. The program will close, and when I reopen the toolbar is set to Office Icons. You can actually change any random item on the configuartion dialog, and it will close and result in the same issue.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5953/configuration-bug-in-relelase-version-of-2018</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 07:37:45 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5953.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Apr 2018 16:24:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Tue, 17 Apr 2018 20:25:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/the_purspyk" aria-label="Profile: the_purspyk">@<bdi>the_purspyk</bdi></a> Please check in latest build:<br />
<a href="https://powerarchiver.cachefly.net/2018/powarc180047.exe" target="_blank" rel="noopener noreferrer nofollow ugc">https://powerarchiver.cachefly.net/2018/powarc180047.exe</a></p>
]]></description><link>https://forums.powerarchiver.com/post/36402</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36402</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Wed, 18 Apr 2018 18:14:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/the_purspyk" aria-label="Profile: the_purspyk">@<bdi>the_purspyk</bdi></a> said in <a href="/post/36411">Configuration bug in relelase version of 2018</a>:</p>
<p dir="auto">Seems to be working. Some small observations, during the installation, I dont selelct any of the option ie add items to Start Menu, but PowerArichiver is always added to the Start Menu (this has happened in all versions of the program, and i have mentioned this before). If the program is registerted, would it not be possible to remove the Register Icon from the toolbar. I got the impression initially that my program had not been registered, or grey it out.</p>
<p dir="auto">we will write it up, thanks.</p>
<p dir="auto">As to the register icon, it is under Options in Modern toolbar. You might want to change the settings, upgrade to other version, etc, thats why it is there… otherwise PA clearly states it is registered in about window and unregistered is removed from the caption.</p>
]]></description><link>https://forums.powerarchiver.com/post/36412</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36412</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 18 Apr 2018 18:14:40 GMT</pubDate></item><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Wed, 18 Apr 2018 18:05:47 GMT]]></title><description><![CDATA[<p dir="auto">Seems to be working. Some small observations, during the installation, I dont selelct any of the option ie add items to Start Menu, but PowerArichiver is always added to the Start Menu (this has happened in all versions of the program, and i have mentioned this before). If the program is registerted, would it not be possible to remove the Register Icon from the toolbar. I got the impression initially that my program had not been registered, or grey it out.</p>
]]></description><link>https://forums.powerarchiver.com/post/36411</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36411</guid><dc:creator><![CDATA[The_PurSpyk]]></dc:creator><pubDate>Wed, 18 Apr 2018 18:05:47 GMT</pubDate></item><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Tue, 17 Apr 2018 20:25:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/the_purspyk" aria-label="Profile: the_purspyk">@<bdi>the_purspyk</bdi></a> Please check in latest build:<br />
]]></description><link>https://forums.powerarchiver.com/post/36402</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36402</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:25:13 GMT</pubDate></item><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Wed, 11 Apr 2018 18:38:05 GMT]]></title><description><![CDATA[<p dir="auto">I try tonight and it’s working for me. I have not this issue with PA 2018 (full version) on Windows 10 RS4 17133.73 x64.</p>
]]></description><link>https://forums.powerarchiver.com/post/36386</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36386</guid><dc:creator><![CDATA[ffm76600]]></dc:creator><pubDate>Wed, 11 Apr 2018 18:38:05 GMT</pubDate></item><item><title><![CDATA[Reply to Configuration bug in relelase version of 2018 on Wed, 11 Apr 2018 17:23:16 GMT]]></title><description><![CDATA[<p dir="auto">thanks very much for this report!<br />
we are logging it in for fixing</p>
]]></description><link>https://forums.powerarchiver.com/post/36385</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36385</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 11 Apr 2018 17:23:16 GMT</pubDate></item></channel></rss>
