<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 18.00.41 and Start Menu]]></title><description><![CDATA[<p dir="auto">Start menu folder.<br />
At least on my PC PowerArchiver 2018 still uses a Start menu folder called “PowerArchiver 2017”.<br />
<img src="/assets/uploads/files/1521567003073-pa-start-menu.png" alt="0_1521566999828_PA Start menu.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/5941/pa-18-00-41-and-start-menu</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 19:14:20 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5941.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Mar 2018 17:31:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 18.00.41 and Start Menu on Fri, 06 Apr 2018 23:27:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: Brian-Gregory">@<bdi>Brian-Gregory</bdi></a> so in one of the latest versions we now clean up old program group, rename it to PowerArchiver and also delete old shortcut to PA 2017. So now when you upgrade from 2017 to 2018 all is nice and proper on Windows 7 and earlier system. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/36379</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36379</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 06 Apr 2018 23:27:36 GMT</pubDate></item><item><title><![CDATA[Reply to PA 18.00.41 and Start Menu on Wed, 21 Mar 2018 09:57:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> said in <a href="/post/36307">PA 18.00.41 and Start Menu</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> said in <a href="/post/36306">PA 18.00.41 and Start Menu</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> said in <a href="/post/36305">PA 18.00.41 and Start Menu</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> try deleting the program group and simply reinstalling over existing setup.</p>
<p dir="auto">It should be PowerArchiver group now.</p>
<p dir="auto">If there was a previous group, it will use it hence the issue.</p>
<p dir="auto">thanks!</p>
<p dir="auto">I just tried that.<br />
It just re-created the “PowerArchiver 2017” group but with only one icon in it called “PowerArchiver 2018”.</p>
<p dir="auto">Yeah, I just checked it now to be sure - so it requires uninstall and then next install of Pa 2018 will properly have PowerArchiver group… I guess it takes info from the registry about already existing program group.</p>
<p dir="auto">Yes that works. But I had to manually delete the old “PowerArchiver 2017” group. Uninstalliing did not remove it.</p>
<p dir="auto">This board was semi down again saying “connection lost” earlier so I couldn’t reply earlier.</p>
]]></description><link>https://forums.powerarchiver.com/post/36310</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36310</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Wed, 21 Mar 2018 09:57:16 GMT</pubDate></item><item><title><![CDATA[Reply to PA 18.00.41 and Start Menu on Tue, 20 Mar 2018 22:43:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> said in <a href="/post/36306">PA 18.00.41 and Start Menu</a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/36307</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36307</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 20 Mar 2018 22:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to PA 18.00.41 and Start Menu on Tue, 20 Mar 2018 22:24:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> said in <a href="/post/36305">PA 18.00.41 and Start Menu</a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/36306</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36306</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Tue, 20 Mar 2018 22:24:16 GMT</pubDate></item><item><title><![CDATA[Reply to PA 18.00.41 and Start Menu on Tue, 20 Mar 2018 18:43:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: brian-gregory">@<bdi>brian-gregory</bdi></a> try deleting the program group and simply reinstalling over existing setup.</p>
]]></description><link>https://forums.powerarchiver.com/post/36305</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/36305</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 20 Mar 2018 18:43:37 GMT</pubDate></item></channel></rss>
