<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Drag and Drop files to existing archive - overwrite prompt]]></title><description><![CDATA[<p dir="auto">Dragging and dropping files in explorer onto an existing archive file(PA not open) brings up the “Add” dialogue box showing the archive file and the files to be added.</p>
<p dir="auto">After clicking the Finish button to complete the archiving, a dialogue box appears saying:<br />
“Cannot create <em>[filename]</em>. File already exists.  Update existing file?”  with Yes and No buttons.</p>
<p dir="auto">Is it possible to default to adding/moving the files to the archive without this prompt?  The prompt seems redundant given the “Add” dialogue can only mean one thing for the selected archive file.  This is a change in behaviour from PA2016 which added or moved files without any permission being sought.<br />
Edit: spelling</p>
]]></description><link>https://forums.powerarchiver.com/topic/5844/drag-and-drop-files-to-existing-archive-overwrite-prompt</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 01:29:06 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5844.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Sep 2017 05:46:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Thu, 05 Oct 2017 00:19:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/south37" aria-label="Profile: south37">@<bdi>south37</bdi></a> Please check latest build and confirm that this issue has been fixed. Thank you!</p>
<p dir="auto"><a href="https://forums.powerarchiver.com/topic/5848/fast-ring-powerarchiver-2017-17-01-04/7">https://forums.powerarchiver.com/topic/5848/fast-ring-powerarchiver-2017-17-01-04/7</a></p>
]]></description><link>https://forums.powerarchiver.com/post/35557</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35557</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 05 Oct 2017 00:19:51 GMT</pubDate></item><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Thu, 05 Oct 2017 22:52:15 GMT]]></title><description><![CDATA[<p dir="auto">Given that there are more users than developers, perhaps the Shift+ method should be used to enable the dialogue box with the default being no overwrite query.  Just my opinion. Look forward to a resolution.</p>
]]></description><link>https://forums.powerarchiver.com/post/35583</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35583</guid><dc:creator><![CDATA[south37]]></dc:creator><pubDate>Thu, 05 Oct 2017 22:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Thu, 05 Oct 2017 13:00:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/south37" aria-label="Profile: south37">@<bdi>south37</bdi></a> said in <a href="/post/35560">Drag and Drop files to existing archive - overwrite prompt</a>:</p>
<p dir="auto">No, just installed ver 17.01.04 and the behaviour is still the same.</p>
<p dir="auto">Ah, yes. We have removed the update/overwrite dialogue when you are drag and droping onto archive opened in main window.</p>
<p dir="auto">But we have left it here - since many of us internally use this to overwite archive, not update.</p>
<p dir="auto">Maybe solution in the future would be to detect hold shift for instance when drag and drop, to use it for update? Or ctrl for overwrite? Or? <a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> <a class="plugin-mentions-group plugin-mentions-a" href="/groups/alpha-testers" aria-label="Profile: Alpha-Testers">@<bdi>Alpha-Testers</bdi></a></p>
]]></description><link>https://forums.powerarchiver.com/post/35571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35571</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 05 Oct 2017 13:00:49 GMT</pubDate></item><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Thu, 05 Oct 2017 01:40:59 GMT]]></title><description><![CDATA[<p dir="auto">No, just installed ver 17.01.04 and the behaviour is still the same.</p>
]]></description><link>https://forums.powerarchiver.com/post/35560</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35560</guid><dc:creator><![CDATA[south37]]></dc:creator><pubDate>Thu, 05 Oct 2017 01:40:59 GMT</pubDate></item><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Thu, 05 Oct 2017 00:19:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/south37" aria-label="Profile: south37">@<bdi>south37</bdi></a> Please check latest build and confirm that this issue has been fixed. Thank you!</p>
]]></description><link>https://forums.powerarchiver.com/post/35557</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35557</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 05 Oct 2017 00:19:51 GMT</pubDate></item><item><title><![CDATA[Reply to Drag and Drop files to existing archive - overwrite prompt on Sun, 24 Sep 2017 11:40:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/south37" aria-label="Profile: south37">@<bdi>south37</bdi></a> thanks, wrote it in… will update the thread once solution is in place.</p>
]]></description><link>https://forums.powerarchiver.com/post/35528</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35528</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 24 Sep 2017 11:40:06 GMT</pubDate></item></channel></rss>
