<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Occasional Application Error in W7 - PA 17.00.83]]></title><description><![CDATA[<p dir="auto">This error is happening, apparently randomly. Log and error message attached.</p>
<p dir="auto"><img src="/assets/uploads/files/1500020110491-capture.jpg" alt="0_1500020111559_Capture.JPG" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1500020120112-pa-error-log-resized.jpg" alt="0_1500020121708_pa-error-log.JPG" class=" img-fluid img-markdown" /><br />
I’ll’ try to see if it can be related to anything else, but the effect is to crash PA or to stop and archive activities without crash i.e. can’t add files etc.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5797/occasional-application-error-in-w7-pa-17-00-83</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 03:25:15 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5797.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Jul 2017 08:17:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Occasional Application Error in W7 - PA 17.00.83 on Tue, 18 Jul 2017 10:37:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a> It seems to happen when either Macrium Reflect or Acronis are running; I suspect the former.</p>
]]></description><link>https://forums.powerarchiver.com/post/35118</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35118</guid><dc:creator><![CDATA[PA_Fan]]></dc:creator><pubDate>Tue, 18 Jul 2017 10:37:17 GMT</pubDate></item><item><title><![CDATA[Reply to Occasional Application Error in W7 - PA 17.00.83 on Fri, 14 Jul 2017 11:07:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the report!<br />
If you notice a specific action in operation that might hint at the cause, please let us know and we will test.</p>
]]></description><link>https://forums.powerarchiver.com/post/35105</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35105</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Fri, 14 Jul 2017 11:07:34 GMT</pubDate></item></channel></rss>
