<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 9.2 Bug: Relative folder info is NOT stored]]></title><description><![CDATA[<p dir="auto">if you add more than 2 directories to an archive. PA will save the full path and not the relative path, even if you have deselected “Save full folder info”. I added the directories to the PA window by drag &amp; Drop</p>
]]></description><link>https://forums.powerarchiver.com/topic/577/pa-9-2-bug-relative-folder-info-is-not-stored</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 02:24:47 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/577.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Feb 2005 09:48:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Tue, 08 Mar 2005 12:27:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klumy" aria-label="Profile: klumy">@<bdi>klumy</bdi></a>:</p>
<p dir="auto">bug seems to be fixed now in the newest final ;)</p>
<p dir="auto">eh, you didnt download latest, did you? :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/7790</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7790</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 08 Mar 2005 12:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Tue, 08 Mar 2005 11:06:34 GMT]]></title><description><![CDATA[<p dir="auto">bug seems to be fixed now in the newest final ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/7787</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7787</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Tue, 08 Mar 2005 11:06:34 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 07 Mar 2005 14:48:53 GMT]]></title><description><![CDATA[<ul>
<li>
<p dir="auto">normal files works OK</p>
</li>
<li>
<p dir="auto">directories NOT OK</p>
</li>
</ul>
<p dir="auto">e.g.<br />
I d&amp;D the folder E:\Eigene Dateien\AquaNox2\576</p>
<p dir="auto">to an archive</p>
<p dir="auto">E:\Eigene Dateien\AquaNox2\Savegame2.zip</p>
<p dir="auto">the directory will be added as<br />
AquaNox2\576</p>
<p dir="auto">and not as 576</p>
]]></description><link>https://forums.powerarchiver.com/post/7775</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7775</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Mon, 07 Mar 2005 14:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 07 Mar 2005 14:39:17 GMT]]></title><description><![CDATA[<p dir="auto">It sure works for me - test with some deeper folder to make sure it works/doesnt work…</p>
]]></description><link>https://forums.powerarchiver.com/post/7774</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7774</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 07 Mar 2005 14:39:17 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 07 Mar 2005 11:54:53 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Hey, it is you that posted in the wrong thread :-). This was about storing relative info when d&amp;d several folders into zip archive… It should work much faster as well now.</p>
<p dir="auto">you are right</p>
<p dir="auto">But the relative folder info still doesn’t work</p>
<p dir="auto">I open the archive<br />
F:\Temp\21 - Track 21.zip</p>
<p dir="auto">Then I drag&amp;Drop the folder F:\Temp\kjlkjj with some mp3 files into the upper ZIP file</p>
<p dir="auto">PA will store it as</p>
<p dir="auto">Temp\kjlkjj in the main directory of the zip file and not as kjlkjj</p>
]]></description><link>https://forums.powerarchiver.com/post/7770</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7770</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Mon, 07 Mar 2005 11:54:53 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 07 Mar 2005 11:29:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klumy" aria-label="Profile: klumy">@<bdi>klumy</bdi></a>:</p>
<p dir="auto">still doesn’t work in 9.20.07</p>
<p dir="auto">can’t drag&amp;drop empty folders to an existing archive</p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/7768</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7768</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 07 Mar 2005 11:29:49 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 07 Mar 2005 11:24:16 GMT]]></title><description><![CDATA[<p dir="auto">eh, it is not “supposed” to work, I posted link in wrong thread :-).</p>
]]></description><link>https://forums.powerarchiver.com/post/7765</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7765</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 07 Mar 2005 11:24:16 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Sun, 06 Mar 2005 21:13:10 GMT]]></title><description><![CDATA[<p dir="auto">still doesn’t work in 9.20.07</p>
]]></description><link>https://forums.powerarchiver.com/post/7760</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7760</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Sun, 06 Mar 2005 21:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Sun, 06 Mar 2005 02:18:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">you can test new release from here:<br />
<a href="http://www.powerarchiver.com/test/release/powarc920.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release/powarc920.exe</a></p>
<p dir="auto">Please let us know if it works fine asap.</p>
]]></description><link>https://forums.powerarchiver.com/post/7743</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7743</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 06 Mar 2005 02:18:54 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Mon, 28 Feb 2005 09:21:14 GMT]]></title><description><![CDATA[<p dir="auto">never mind</p>
<p dir="auto">I am glad to help out</p>
]]></description><link>https://forums.powerarchiver.com/post/7669</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7669</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Mon, 28 Feb 2005 09:21:14 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Sun, 27 Feb 2005 23:12:17 GMT]]></title><description><![CDATA[<p dir="auto">Yep, thanks for the report. Awesome. When you select several folders to d&amp;d into archive, it doesnt work properly and stores full path.</p>
<p dir="auto">thanks for the find!</p>
]]></description><link>https://forums.powerarchiver.com/post/7665</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7665</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 27 Feb 2005 23:12:17 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Sun, 27 Feb 2005 10:30:29 GMT]]></title><description><![CDATA[<p dir="auto">ZIP</p>
<p dir="auto">I opened the ZIP in PA. Then I added the files from the windows explorer to the PA main window. In the following add dialog I deselected “Save full folder info”.</p>
]]></description><link>https://forums.powerarchiver.com/post/7648</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7648</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Sun, 27 Feb 2005 10:30:29 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.2 Bug: Relative folder info is NOT stored on Sun, 27 Feb 2005 10:25:45 GMT]]></title><description><![CDATA[<p dir="auto">Which format?</p>
<p dir="auto">How did you tried to add (main window, shell extensions?)?</p>
]]></description><link>https://forums.powerarchiver.com/post/7647</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7647</guid><dc:creator><![CDATA[ivan]]></dc:creator><pubDate>Sun, 27 Feb 2005 10:25:45 GMT</pubDate></item></channel></rss>
