<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cancelling compressing a folder into a .PA is really slow (17.00.70)]]></title><description><![CDATA[<p dir="auto">Cancelling compressing a large folder into a .PA is really slow (17.00.70).<br />
Basically it seems to carry on compressing and output to the PA file for ages after I cancelled it.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5766/cancelling-compressing-a-folder-into-a-pa-is-really-slow-17-00-70</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 07:21:33 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5766.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 May 2017 00:26:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Tue, 06 Jun 2017 22:49:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> Yes. I think it’s better. I wish I could remember the exact folder I was using before, but I can’t. It seems fast enough now anyway.</p>
]]></description><link>https://forums.powerarchiver.com/post/34913</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34913</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Tue, 06 Jun 2017 22:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Tue, 06 Jun 2017 12:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: Brian-Gregory">@<bdi>Brian-Gregory</bdi></a> moved it from alpha testing forums… now it works properly</p>
<p dir="auto">Please check with this release, should be much better:<br />
<a href="https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70-71-73">https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70-71-73</a></p>
]]></description><link>https://forums.powerarchiver.com/post/34899</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34899</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 06 Jun 2017 12:13:06 GMT</pubDate></item><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Sun, 04 Jun 2017 09:34:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: Brian-Gregory">@<bdi>Brian-Gregory</bdi></a> moved it from alpha testing forums… now it works properly when new archive is being cancelled, it stops instantly. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/34895</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34895</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 04 Jun 2017 09:34:57 GMT</pubDate></item><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Fri, 12 May 2017 12:40:31 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: Brian-Gregory">@<bdi>Brian-Gregory</bdi></a>!<br />
We have it noticed and logged in</p>
]]></description><link>https://forums.powerarchiver.com/post/34859</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34859</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Fri, 12 May 2017 12:40:31 GMT</pubDate></item><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Fri, 12 May 2017 01:55:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> It was a new archive.</p>
]]></description><link>https://forums.powerarchiver.com/post/34858</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34858</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Fri, 12 May 2017 01:55:10 GMT</pubDate></item><item><title><![CDATA[Reply to Cancelling compressing a folder into a .PA is really slow (17.00.70) on Fri, 12 May 2017 00:29:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/brian-gregory" aria-label="Profile: Brian-Gregory">@<bdi>Brian-Gregory</bdi></a> i think it has to finish current file or archive being created could end up corrupted. Was this existing archive or new one?</p>
]]></description><link>https://forums.powerarchiver.com/post/34857</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34857</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 12 May 2017 00:29:41 GMT</pubDate></item></channel></rss>
