<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Memory leak compressing ubuntu-17.04-desktop-amd64.iso]]></title><description><![CDATA[<p dir="auto">I have read at <a href="https://encode.ru/threads/130-PowerArchiver?p=52611&amp;viewfull=1#post52611" target="_blank" rel="noopener noreferrer nofollow ugc">https://encode.ru/threads/130-PowerArchiver?p=52611&amp;viewfull=1#post52611</a> that FreeArc Next has the better compression ration while compressing ubuntu-17.04-desktop-amd64.iso.</p>
<p dir="auto">So I tried the same with PA 17.00.69. Good news is that you guys, made it, making an even smaller resulting file.</p>
<p dir="auto">The thing is that I guess I have detected a memory leak, because memory usage reached the 2GB while compressing, which should not be the case, considering that a 24MB PLZMA dictionary with 4 execution threads is about 900MB of memory usage.</p>
<p dir="auto">For your information, in the same scenario, WinRAR was at 800MB of memory usage on peak.</p>
<p dir="auto">Can you please take a look? Maybe I am wrong, and this is the normal behaviour. Maybe Windows Task Manager is not properly reporting the usage.</p>
<p dir="auto">Thanks.</p>
<p dir="auto"><img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/2gb.png" alt="2GB" class=" img-fluid img-markdown" /><br />
<img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/2gb_options.png" alt="2GB options" class=" img-fluid img-markdown" /><br />
<img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/2gb_advanced_options.png" alt="2GB advanced options" class=" img-fluid img-markdown" /><br />
<img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/2gb_ubuntu.png" alt="2GB Ubuntu" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/5763/memory-leak-compressing-ubuntu-17-04-desktop-amd64-iso</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 17:24:41 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5763.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 May 2017 08:13:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 06 Jun 2017 12:19:00 GMT]]></title><description><![CDATA[<p dir="auto">check with large D with new release:<br />
<a href="https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70-71-73">https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70-71-73</a></p>
]]></description><link>https://forums.powerarchiver.com/post/34904</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34904</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 06 Jun 2017 12:19:00 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 14:09:43 GMT]]></title><description><![CDATA[<p dir="auto">of course, for us, we cant set more than 64m by default, it would be unreasonable… but sure, it is fun for testing :)</p>
]]></description><link>https://forums.powerarchiver.com/post/34830</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34830</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 14:09:43 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 13:54:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikkho" aria-label="Profile: nikkho">@<bdi>nikkho</bdi></a> memory is not a problem on x64, it works well. Of course, it is also dependent on dictionary size.</p>
]]></description><link>https://forums.powerarchiver.com/post/34829</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34829</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 13:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 13:50:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikkho" aria-label="Profile: nikkho">@<bdi>nikkho</bdi></a> try c=256M, it will go down more :)</p>
]]></description><link>https://forums.powerarchiver.com/post/34828</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34828</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 13:50:01 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 11:32:45 GMT]]></title><description><![CDATA[<p dir="auto">With the new settings, the reduction was amazing, going from 1.571.555.291 bytes to 1.037.033.705 bytes!!<br />
Switches wers: c_out=plzma4:mt4:c16M:d128M:mc16:fb273:lc1:lp0:pb0:a1; c_adr=plzma4:mt1:d22:lc0:pb2:lp2:fb273;  c_hif=lzma2:x1:d22:mt1;  rep1:fb15000:c300M:mem2000M { reflate:x9{ x64flt2{ deltb:c=1000K { deltb:c=1001K { c_out }} } / c_hif } }</p>
<p dir="auto">As espected, peak memory usage raised to about 6GB with those new settings, but speed was comparable to previous trial.</p>
<p dir="auto"><img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/max-01.png" alt="Max 01" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="http://www.javiergutierrezchamorro.com/_temp/upload/pa17.00.69/max-02.png" alt="Max 02" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/34826</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34826</guid><dc:creator><![CDATA[nikkho]]></dc:creator><pubDate>Tue, 09 May 2017 11:32:45 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 09:40:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikkho" aria-label="Profile: nikkho">@<bdi>nikkho</bdi></a> btw, for me, real winner is Optimized Fast and Ultra or Max mode. It will finish in 30s on my computer and still be reasonably smaller due to rep1 :). Effect is better on other isos that are not as compressed as this one.</p>
]]></description><link>https://forums.powerarchiver.com/post/34821</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34821</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 09:40:51 GMT</pubDate></item><item><title><![CDATA[Reply to Memory leak compressing ubuntu-17.04-desktop-amd64.iso on Tue, 09 May 2017 09:38:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nikkho" aria-label="Profile: nikkho">@<bdi>nikkho</bdi></a> there is no memory leak, those settings only apply to custom mode, not to optimized strong mode. So you are using a lot of memory of course, 64M at those settings (extreme), and also real 4 threads are used for that file. Advanced tab is least worked on feature in PA so far :). Many improvements there are still possible.</p>
<p dir="auto">That file is compressed, so i think advantage comes due to lzmarec coder + rep1 dedup. I think it would do even better with 128 MB, lets try it :)</p>
]]></description><link>https://forums.powerarchiver.com/post/34820</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34820</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 09:38:57 GMT</pubDate></item></channel></rss>
