<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[settings for wav&#x2F;sf2 files (from 17.00.68)]]></title><description><![CDATA[<p dir="auto">thread for delta/plzma4:a0 settings discussion, moved from:<br />
<a href="https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69">https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69</a></p>
<p dir="auto">since on version specific thread it will be pushed back on thread list quite fast.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5753/settings-for-wav-sf2-files-from-17-00-68</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 11:04:52 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5753.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 May 2017 20:29:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to settings for wav&#x2F;sf2 files (from 17.00.68) on Tue, 09 May 2017 16:28:01 GMT]]></title><description><![CDATA[<p dir="auto">.70 adds larger dictionary and chunk sizes in stronger options for wav mode, also added sf2 to that mode.<br />
<a href="https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70">https://forums.powerarchiver.com/topic/5747/fast-ring-powerarchiver-2017-17-00-67-68-69-70</a></p>
]]></description><link>https://forums.powerarchiver.com/post/34835</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34835</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 09 May 2017 16:28:01 GMT</pubDate></item><item><title><![CDATA[Reply to settings for wav&#x2F;sf2 files (from 17.00.68) on Thu, 04 May 2017 15:02:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> Please find a collection of samples in this file:<br />
<a href="https://drive.google.com/file/d/0ByLIAFlgldSoMDJMTGVwVnB2Rmc/view?usp=sharing" target="_blank" rel="noopener noreferrer nofollow ugc">here</a></p>
<p dir="auto">Let me know if you need further files.</p>
]]></description><link>https://forums.powerarchiver.com/post/34792</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34792</guid><dc:creator><![CDATA[Stephan]]></dc:creator><pubDate>Thu, 04 May 2017 15:02:07 GMT</pubDate></item><item><title><![CDATA[Reply to settings for wav&#x2F;sf2 files (from 17.00.68) on Wed, 03 May 2017 20:36:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/stephan" aria-label="Profile: Stephan">@<bdi>Stephan</bdi></a> we have optimized switches for 16 bit stereo. We assume that is the most commonly used format, hence the delta:4 and lp2, pb2. With higher chunk size and dictionary in next version, it is not only faster than ppmd_sh but also compresses better on our “real” life samples. That goes the same for sf2 files (also tested au but did not work there).</p>
<p dir="auto">For bmp, our results were too varied and we could not pick a single setting to use on our samples. So that will have to wait for detector to be built first.</p>
<p dir="auto">MA is a lock, likely for the next release, but we will still need fast settings with delta for faster modes, so detector for wavs will also be beneficial in the future.</p>
<p dir="auto">Can you send me those sound modules files for testing, if we can replicate results on larger amount of samples, we would also include it for next release.</p>
<p dir="auto">Thanks a lot for the feedback!</p>
]]></description><link>https://forums.powerarchiver.com/post/34763</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34763</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 03 May 2017 20:36:06 GMT</pubDate></item><item><title><![CDATA[Reply to settings for wav&#x2F;sf2 files (from 17.00.68) on Wed, 03 May 2017 18:29:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> worth to mention are also those audio formats: .xi (instruments), in some rare cases there are .au and .aif/.aiff, .voc and .snd</p>
]]></description><link>https://forums.powerarchiver.com/post/34760</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34760</guid><dc:creator><![CDATA[Stephan]]></dc:creator><pubDate>Wed, 03 May 2017 18:29:35 GMT</pubDate></item><item><title><![CDATA[Reply to settings for wav&#x2F;sf2 files (from 17.00.68) on Wed, 03 May 2017 18:24:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> compression of sounds is much more than delta on .wav. Wav can have different bit depths and number of channels which affect delta number - delta:1 is good for 8-bit mono, delta:2 is good for 8-bit stereo, delta:4 is good for 16-bit stereo…</p>
<p dir="auto">Sound modules (.dmf, .it, .med, .mod, .mptm, .okt, .rns, .s3m, .umx, .xm) and soundfonts (.sf2): most of them support 8-bit mono and stereo, some also contain 16-bit mono and stereo. If you are using 7z delta filter for files like this, I would recommend delta:2 + LZMA for all sound modules except .s3m which are compressed better using delta:1 + LZMA.</p>
<p dir="auto">delta:3 + PPMd:mem256m:o3 would help on all non-compressed images in 24-bit such as .PPM, .PNM and also .PAM; with LZMA2 instead of PPMd delta:3 would help on all camera raw in Mamiya .mef format while delta:4 would help on all camera raw in Leaf .mos format and on uncompressed Sony .arw.<br />
Soundfonts are compressed best by closed-source sfArk (nothing practical comes close atm), but libbsc -b1024rcf -m0 -H28 is good here. A parser with Monkeys Audio would be superior to both.</p>
]]></description><link>https://forums.powerarchiver.com/post/34759</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34759</guid><dc:creator><![CDATA[Stephan]]></dc:creator><pubDate>Wed, 03 May 2017 18:24:47 GMT</pubDate></item></channel></rss>
