<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OpenPGP Support]]></title><description><![CDATA[<p dir="auto">Both 2016 and 17 encrypt to every public key I have, no matter who or how many recipients I choose.  If I choose only one recipient, out of five possible recipients, the file will be encrypted to all five instead of just the one selected. Is this a bug or am I doing something wrong?</p>
]]></description><link>https://forums.powerarchiver.com/topic/5726/openpgp-support</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 13:39:46 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5726.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Mar 2017 18:14:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OpenPGP Support on Fri, 31 Mar 2017 16:31:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bigdog" aria-label="Profile: bigdog">@<bdi>bigdog</bdi></a> said in <a href="/topic/5726/openpgp-support/3">OpenPGP Support</a>:</p>
<p dir="auto">I believe you always have to sign a file to encrypt it. That is part of the PGP standard.</p>
<p dir="auto">No, I can perfectly encrypt files using GnuPG without signing. Even in strict OpenPGP mode.</p>
]]></description><link>https://forums.powerarchiver.com/post/34686</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34686</guid><dc:creator><![CDATA[BigMike]]></dc:creator><pubDate>Fri, 31 Mar 2017 16:31:16 GMT</pubDate></item><item><title><![CDATA[Reply to OpenPGP Support on Mon, 27 Mar 2017 14:59:59 GMT]]></title><description><![CDATA[<p dir="auto">will take a close  look at the reported issues and log issues in/report back as necessary.</p>
<p dir="auto">thanks very much all for the details</p>
]]></description><link>https://forums.powerarchiver.com/post/34654</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34654</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 27 Mar 2017 14:59:59 GMT</pubDate></item><item><title><![CDATA[Reply to OpenPGP Support on Sun, 26 Mar 2017 18:10:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robertm" aria-label="Profile: RobertM">@<bdi>RobertM</bdi></a> said in <a href="/post/34649">OpenPGP Support</a>:</p>
<p dir="auto">As for making signing of files compulsory, all I will say is that most, if not all, GnuPG front-ends allow encryption without signing, including GPA and Kleopatra.</p>
<p dir="auto">I stand corrected. I thought that you needed to sign a file as part of encrypting to certify it but I looked again and you are correct.</p>
<p dir="auto">Now hopefully PA can fix the issues with PGP</p>
]]></description><link>https://forums.powerarchiver.com/post/34650</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34650</guid><dc:creator><![CDATA[bigdog]]></dc:creator><pubDate>Sun, 26 Mar 2017 18:10:50 GMT</pubDate></item><item><title><![CDATA[Reply to OpenPGP Support on Sat, 25 Mar 2017 23:12:41 GMT]]></title><description><![CDATA[<p dir="auto">I’ll go ahead and share my other issue with the GnuPG support.</p>
<p dir="auto">If I have more than one private key, I’m asked to enter a password (for signing) for each private key I have - even though I’ve selected only one signing key and only one is possible.</p>
<p dir="auto">So here’s the drill:</p>
<p dir="auto">Let’s say my keyring has ten public keys of others and two personal key-pairs of my own.  I want to encrypt to one of my personal keys and one other key - and sign with one of my two private keys.  So I choose myself and one other recipient, for a total of two recipients.  Obviously I will have chosen only one of my two keys for signing.  I will be asked to enter passwords for <em>both</em> of my private keys and the file will be encrypted to twelve recipients!  My actual keyring is decades old and contains dozens of keys. Using it with PA is therefore impractical.</p>
]]></description><link>https://forums.powerarchiver.com/post/34649</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34649</guid><dc:creator><![CDATA[RobertM]]></dc:creator><pubDate>Sat, 25 Mar 2017 23:12:41 GMT</pubDate></item><item><title><![CDATA[Reply to OpenPGP Support on Sat, 25 Mar 2017 18:55:15 GMT]]></title><description><![CDATA[<p dir="auto">It definitely has issues with PGP and keys. I reported a bug well over a year ago about it not displaying the name on the key correctly and so far it has not been fixed.</p>
]]></description><link>https://forums.powerarchiver.com/post/34648</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34648</guid><dc:creator><![CDATA[bigdog]]></dc:creator><pubDate>Sat, 25 Mar 2017 18:55:15 GMT</pubDate></item><item><title><![CDATA[Reply to OpenPGP Support on Fri, 24 Mar 2017 21:48:21 GMT]]></title><description><![CDATA[<p dir="auto">I can confirm this, and there seems to be more work with the encryption of files :'(</p>
<ul>
<li>In the key selection dialog, I see other keys, than in my default key manager, so somehow, PowerArchiver uses its own keyring, but doesn’t sync it properly.</li>
<li>I’m not able to display the trust values of the keys</li>
<li>The back arrow in the key selection window has no function, the back arrow in the password window cancels the operation and closes the dialog (while a 0 byte file stays behind)</li>
<li>The password dialog isn’t intuitive at all - it’s the dialog for creating a new password - you need to retype the password, you get a warning on weak passwords and a password policy is displayed. But actually, you need to enter the existing password of your private key</li>
<li>It seems you can’'t create an encrypted file without signing it</li>
</ul>
]]></description><link>https://forums.powerarchiver.com/post/34642</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/34642</guid><dc:creator><![CDATA[BigMike]]></dc:creator><pubDate>Fri, 24 Mar 2017 21:48:21 GMT</pubDate></item></channel></rss>
