<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tar issue]]></title><description><![CDATA[<p dir="auto">I have the latest version of PA (2016) Windows 10 and I am getting permissions errors, files are not valid etc when extracting TAR files from a folder downloaded from our host.</p>
<p dir="auto">I have not experienced these errors before, or had to start PA as admin (what a crock), I have used PA to extract backup folders from our host for years.</p>
<p dir="auto">See error warnings</p>
<p dir="auto"><a href="http://www.ripefruit.com/images/pa-1.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ripefruit.com/images/pa-1.jpg</a></p>
<p dir="auto"><a href="http://www.ripefruit.com/images/pa-2.jpg" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.ripefruit.com/images/pa-2.jpg</a></p>
<p dir="auto">PA, sort it out. The only thing thats changed is PA</p>
]]></description><link>https://forums.powerarchiver.com/topic/5502/tar-issue</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 16:09:30 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5502.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Jul 2016 23:34:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tar issue on Sat, 30 Jul 2016 19:00:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ripefruit" aria-label="Profile: ripefruit">@<bdi>ripefruit</bdi></a>:</p>
<p dir="auto">I have had to use 7-zip on 3 occasions today to first extract the contents of a TAR file, and then I was able to use PA to extract the files located within a sub folder so it looks to me like the issue is the downloaded TAR folder.</p>
<p dir="auto">can you please update to latest release:<br />
<a href="http://dl.powerarchiver.com/2016/powarc161014.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://dl.powerarchiver.com/2016/powarc161014.exe</a></p>
<p dir="auto">And let us know if it works properly. I remember we solved some issues with tar engine. Basically what is likely happening (cant be sure without example) is that unix filesystem allows more characters in file and folder names. They cant be extracted properly in Windows file system as is, that would return an “permissions” error. We have workarounds for these, but it is possible that some version introduced new issue, I remember us talking about something similar few months ago - so it is either fixed due to report or we re-introduced the issue in latest release.</p>
<p dir="auto">Thanks for checking it out!</p>
]]></description><link>https://forums.powerarchiver.com/post/33382</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33382</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 30 Jul 2016 19:00:19 GMT</pubDate></item><item><title><![CDATA[Reply to Tar issue on Sat, 30 Jul 2016 14:30:45 GMT]]></title><description><![CDATA[<p dir="auto">Try the latest version of Power Archiver first. (16.10.14).<br />
If you don’t fancy attaching one of the files here you can always just post the URL where you downloaded one of them.</p>
]]></description><link>https://forums.powerarchiver.com/post/33381</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33381</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Sat, 30 Jul 2016 14:30:45 GMT</pubDate></item><item><title><![CDATA[Reply to Tar issue on Sat, 30 Jul 2016 07:53:15 GMT]]></title><description><![CDATA[<p dir="auto">I have had to use 7-zip on 3 occasions today to first extract the contents of a TAR file, and then I was able to use PA to extract the files located within a sub folder so it looks to me like the issue is the downloaded TAR folder.</p>
]]></description><link>https://forums.powerarchiver.com/post/33380</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33380</guid><dc:creator><![CDATA[ripefruit]]></dc:creator><pubDate>Sat, 30 Jul 2016 07:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to Tar issue on Sat, 30 Jul 2016 03:00:01 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for letting us know. What version of PA are you using, and is it possible to send us example tar file that doesnt work?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/33379</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33379</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 30 Jul 2016 03:00:01 GMT</pubDate></item><item><title><![CDATA[Reply to Tar issue on Sat, 30 Jul 2016 01:39:28 GMT]]></title><description><![CDATA[<p dir="auto">If PowerArchiver has any doubts, I just downloaded and installed 7-Zip.</p>
<p dir="auto">I ran 7-Zip, extracted the file in under a minute.</p>
<p dir="auto">No errors, no permission issues, no admin user, no issues except a simple extraction.</p>
<p dir="auto">Plus 7-Zip is free software, not paid like my version of PA</p>
<p dir="auto">Very disappointing PowerArchiver</p>
]]></description><link>https://forums.powerarchiver.com/post/33377</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33377</guid><dc:creator><![CDATA[ripefruit]]></dc:creator><pubDate>Sat, 30 Jul 2016 01:39:28 GMT</pubDate></item></channel></rss>
