<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Patches that don&#x27;t reinstall Powerarchiver every time]]></title><description><![CDATA[<p dir="auto">Every time Patchbeam installs a newer version of Powerarchiver, its pretty much like a new install. it asks you to choose what icons you want where as well as other settings, which is annoying if you forget to uncheck the ones you don’t want on the install. Isn’t it possible for Patchbeam to just update Overtop of Powerarchiver silently and adopt the older Powerarchiver settings without going through a full install routine every time?</p>
]]></description><link>https://forums.powerarchiver.com/topic/5501/patches-that-don-t-reinstall-powerarchiver-every-time</link><generator>RSS for Node</generator><lastBuildDate>Sun, 11 Oct 2026 15:39:04 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5501.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 24 Jul 2016 21:56:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Patches that don&#x27;t reinstall Powerarchiver every time on Thu, 21 Sep 2017 02:59:24 GMT]]></title><description><![CDATA[<p dir="auto">this has been added to PA 2017 few months ago. Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/35490</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/35490</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 21 Sep 2017 02:59:24 GMT</pubDate></item><item><title><![CDATA[Reply to Patches that don&#x27;t reinstall Powerarchiver every time on Tue, 01 Nov 2016 17:24:23 GMT]]></title><description><![CDATA[<p dir="auto">from PA 2017, we will have proper patches like before… so in practice, updates will be between 200kb and 2 MB in size and of course no new installation.</p>
]]></description><link>https://forums.powerarchiver.com/post/33497</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33497</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 01 Nov 2016 17:24:23 GMT</pubDate></item><item><title><![CDATA[Reply to Patches that don&#x27;t reinstall Powerarchiver every time on Tue, 01 Nov 2016 13:59:23 GMT]]></title><description><![CDATA[<p dir="auto">like the idea but in practice things like this can cause major problems  not least how long do you hold a patch on the download server etc.  With not having patches you actually only have to do one version of powerarchiver instead of patches and a trial version.</p>
<p dir="auto">Patches are only good if you have everything as modular and can update only that part of powerarchiver.  In truth that may not actually work properly as you would have to have another component telling you what patches are installed in powerarchiver.</p>
]]></description><link>https://forums.powerarchiver.com/post/33495</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33495</guid><dc:creator><![CDATA[splash3313]]></dc:creator><pubDate>Tue, 01 Nov 2016 13:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to Patches that don&#x27;t reinstall Powerarchiver every time on Tue, 01 Nov 2016 08:57:14 GMT]]></title><description><![CDATA[<p dir="auto">Complete agree with this suggestion.</p>
]]></description><link>https://forums.powerarchiver.com/post/33488</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33488</guid><dc:creator><![CDATA[TheAndyMac]]></dc:creator><pubDate>Tue, 01 Nov 2016 08:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to Patches that don&#x27;t reinstall Powerarchiver every time on Thu, 04 Aug 2016 23:29:34 GMT]]></title><description><![CDATA[<p dir="auto">Good idea.</p>
<p dir="auto">It always annoys me to have to say Yes I do want the Queue and no I don’t want the icon on my desktop.</p>
<p dir="auto">Why can’t it default to the options I chose last time?</p>
<p dir="auto">Also a little annoying is that even when a reboot is required after installation the installer defaults to running PA after installation “completes”. But it hasn’t completed properly because I haven’t restarted Windows yet!</p>
<p dir="auto">By the way the reason I don’t want the icon on my desktop is that the icon the installer creates doesn’t seem to be reliable in that it often changes to the default image for a .exe after a few updates. So I create my own desktop icon pointing to POWERARC.EXE and displaying the icon from POWERARC.EXE rather than the icon from some obscure installer file that sometimes seems to cease to exist after further updates.</p>
]]></description><link>https://forums.powerarchiver.com/post/33385</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33385</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Thu, 04 Aug 2016 23:29:34 GMT</pubDate></item></channel></rss>
