<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Internal build: PA 2016 16.10.02]]></title><description><![CDATA[<p dir="auto">Version:<br />
PA 2016 16.10.02 (Internal)</p>
<p dir="auto">Download:<br />
<a href="http://dl.powerarchiver.com/2016/powarc161002.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://dl.powerarchiver.com/2016/powarc161002.exe</a></p>
<p dir="auto">Whats New:</p>
<ul>
<li>Fixes since 16.10.01. Full list to be updated later.</li>
</ul>
]]></description><link>https://forums.powerarchiver.com/topic/5481/internal-build-pa-2016-16-10-02</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Mar 2026 11:59:23 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5481.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 May 2016 23:52:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Internal build: PA 2016 16.10.02 on Wed, 18 May 2016 22:34:58 GMT]]></title><description><![CDATA[<p dir="auto">new internal build:<br />
<a href="http://www.powerarchiver.com/forums/showthread.php?p=35032#post35032" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/forums/showthread.php?p=35032#post35032</a></p>
]]></description><link>https://forums.powerarchiver.com/post/33293</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33293</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 18 May 2016 22:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to Internal build: PA 2016 16.10.02 on Tue, 17 May 2016 22:36:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guido" aria-label="Profile: guido">@<bdi>guido</bdi></a>:</p>
<p dir="auto">is there a space between 0 and 1?</p>
<p dir="auto">see image</p>
<p dir="auto">Probably just the way the particular font renders at that small size.</p>
]]></description><link>https://forums.powerarchiver.com/post/33292</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33292</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Tue, 17 May 2016 22:36:43 GMT</pubDate></item><item><title><![CDATA[Reply to Internal build: PA 2016 16.10.02 on Tue, 17 May 2016 19:55:46 GMT]]></title><description><![CDATA[<p dir="auto">is there a space between 0 and 1?</p>
<p dir="auto">see image<br />
<img src="/uploads/_imported_attachments/attachment_p_35030_0_install.png" alt="attachment_p_35030_0_install.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/33291</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33291</guid><dc:creator><![CDATA[guido]]></dc:creator><pubDate>Tue, 17 May 2016 19:55:46 GMT</pubDate></item><item><title><![CDATA[Reply to Internal build: PA 2016 16.10.02 on Sun, 15 May 2016 22:31:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kribby" aria-label="Profile: Kribby">@<bdi>Kribby</bdi></a>:</p>
<p dir="auto">ZPAQ compression doesn’t work at all</p>
<p dir="auto">When trying to compress a 24.1GB directory that has 33,380 files and 157 sub directories, The compression status window will hang for 20 second, then throw a Visual C++ runtime error saying “R6025 -pure virtual function call”. Windows also throws its own appcrash dialog that says that the fault module is PAZPAG.DLL</p>
<p dir="auto">When trying to compress a 474MB file that has 38 files and 5 sub directories, Powerarchiver shows that it completed the compression process and creates an archive that has a believable size of 232MB. When opening, the archive appears empty. When extracting, nothing happens.</p>
<p dir="auto">thank you, wrote it in.</p>
]]></description><link>https://forums.powerarchiver.com/post/33284</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33284</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 15 May 2016 22:31:10 GMT</pubDate></item><item><title><![CDATA[Reply to Internal build: PA 2016 16.10.02 on Sun, 15 May 2016 22:19:07 GMT]]></title><description><![CDATA[<p dir="auto">ZPAQ compression doesn’t work at all</p>
]]></description><link>https://forums.powerarchiver.com/post/33283</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33283</guid><dc:creator><![CDATA[Kribby]]></dc:creator><pubDate>Sun, 15 May 2016 22:19:07 GMT</pubDate></item></channel></rss>
