<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 16.00.69 - Win 7]]></title><description><![CDATA[<p dir="auto">In previous versions, I feel sure that when a file was deleted from an archive (in my case, almost always .ZIP or .ZIPX), the window automatically refreshed to redisplay the archive minus the deleted file.</p>
<p dir="auto">When I do this now, there is no automatic refresh, and the deleted file remains displayed. F5 will refresh and show the archive minus the file. I’ve tried this with and without Preview enabled, but there is no difference.</p>
<p dir="auto">I attach screenshots of what I think are the most relevant Configuration settings.<br />
<img src="/uploads/_imported_attachments/attachment_t_6521_0_pa69-1.jpg" alt="attachment_t_6521_0_pa69-1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/_imported_attachments/attachment_t_6521_1_pa69-2.jpg" alt="attachment_t_6521_1_pa69-2.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/5449/pa-16-00-69-win-7</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 08:51:51 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5449.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 27 Feb 2016 10:54:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 16.00.69 - Win 7 on Tue, 01 Mar 2016 13:20:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/pa_fan" aria-label="Profile: PA_Fan">@<bdi>PA_Fan</bdi></a>:</p>
<p dir="auto">Thanks.</p>
<p dir="auto">I had a subsequent problem where the skin somehow became corrupt, with all buttons hidden, and thus rendering PA inaccessible.</p>
<p dir="auto">For various reasons, I updated to16.00.69 by downloading the entire file, so was able to use this to repair the installation.</p>
<p dir="auto">When that was complete, PA was restored to normal look (albeit with settings lost) and the delete/refresh problem has been cleared/fixed.</p>
<p dir="auto">when something like that happens next time, try to save the registry so we can reproduce it here. Same goes for the repair, manually deleting HKCU\Software\PowerArchiverint would have likely reset it all back without need to repair.</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/33098</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33098</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 01 Mar 2016 13:20:58 GMT</pubDate></item><item><title><![CDATA[Reply to PA 16.00.69 - Win 7 on Tue, 01 Mar 2016 12:44:46 GMT]]></title><description><![CDATA[<p dir="auto">thanks for the update!</p>
]]></description><link>https://forums.powerarchiver.com/post/33097</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33097</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 01 Mar 2016 12:44:46 GMT</pubDate></item><item><title><![CDATA[Reply to PA 16.00.69 - Win 7 on Tue, 01 Mar 2016 11:58:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a>:</p>
<p dir="auto">seems to work fine here. deleted and refreshed automatically and not showing the deleted file.<br />
any special way you’re deleting it? I’ve tried the delete button on keyboard and right click&gt;delete</p>
<p dir="auto">maybe send your reg settings to support at conexware dot com and we’ll try with those as well<br />
thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/33095</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33095</guid><dc:creator><![CDATA[PA_Fan]]></dc:creator><pubDate>Tue, 01 Mar 2016 11:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to PA 16.00.69 - Win 7 on Mon, 29 Feb 2016 16:58:45 GMT]]></title><description><![CDATA[<p dir="auto">seems to work fine here. deleted and refreshed automatically and not showing the deleted file.<br />
thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/33092</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/33092</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 29 Feb 2016 16:58:45 GMT</pubDate></item></channel></rss>
