<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[File extensions on renaming]]></title><description><![CDATA[<p dir="auto">When renaming files within a ZIP or other archive, would it be possible for the file extensions to be automatically preserved? That would make rename operations much easier as I have some programs that do that so I really miss it when I have a program that does not.</p>
<p dir="auto">Cheers</p>
<p dir="auto">DrT</p>
]]></description><link>https://forums.powerarchiver.com/topic/5392/file-extensions-on-renaming</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 09:56:59 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5392.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 01 Nov 2015 14:15:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to File extensions on renaming on Tue, 03 Nov 2015 11:56:29 GMT]]></title><description><![CDATA[<p dir="auto">logging it in as a feature request, thanks for bringing it up!</p>
]]></description><link>https://forums.powerarchiver.com/post/32645</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32645</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 03 Nov 2015 11:56:29 GMT</pubDate></item><item><title><![CDATA[Reply to File extensions on renaming on Tue, 03 Nov 2015 02:50:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drteeth" aria-label="Profile: drteeth">@<bdi>drteeth</bdi></a>:</p>
<p dir="auto">If you mean like Win 7 does at the moment that would be excellent. Other apps I have, even if the whole filename is selected, do not change it. I do a LOT of file renaming and I hardly ever, well never actually, want the extension to change.</p>
<p dir="auto">Thanks</p>
<p dir="auto">We will checkout what we can do… hopefully we can do the same thing.</p>
]]></description><link>https://forums.powerarchiver.com/post/32641</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32641</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 03 Nov 2015 02:50:23 GMT</pubDate></item><item><title><![CDATA[Reply to File extensions on renaming on Mon, 02 Nov 2015 21:09:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">maybe edit to select only filename part automatically?</p>
]]></description><link>https://forums.powerarchiver.com/post/32640</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32640</guid><dc:creator><![CDATA[drteeth]]></dc:creator><pubDate>Mon, 02 Nov 2015 21:09:53 GMT</pubDate></item><item><title><![CDATA[Reply to File extensions on renaming on Mon, 02 Nov 2015 18:00:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/drteeth" aria-label="Profile: drteeth">@<bdi>drteeth</bdi></a>:</p>
]]></description><link>https://forums.powerarchiver.com/post/32639</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32639</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 02 Nov 2015 18:00:00 GMT</pubDate></item></channel></rss>
