<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 9.11.01 can&#x27;t unzip pkzip files]]></title><description><![CDATA[<p dir="auto">I just upgraded to the new version and I can no longer unzip files created on my old dos laptop with PKZIP 5.0.</p>
<p dir="auto">I can’t be sure this problem is new with the latest version since I haven’t used those files much for a few months but I’m sure whatever version I was using 6 months ago was working fine and I think I’ve probably unzipped a few things since then.</p>
<p dir="auto">I’ve had to copy PKUNZIP to my XP computer to unzip them there.</p>
<p dir="auto">Is this a bug or a new “feature” or is it something I’m overlooking?</p>
<p dir="auto">Thanks,<br />
Barry</p>
]]></description><link>https://forums.powerarchiver.com/topic/536/pa-9-11-01-can-t-unzip-pkzip-files</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 07:59:54 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/536.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Feb 2005 23:33:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Fri, 18 Feb 2005 17:12:15 GMT]]></title><description><![CDATA[<p dir="auto">Check it out with this release:<br />
<a href="http://www.powerarchiver.com/test/release/powarc920.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release/powarc920.exe</a></p>
<p dir="auto">thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/7579</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7579</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 18 Feb 2005 17:12:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Thu, 10 Feb 2005 22:25:00 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Did you try repairing the file via repair tool?</p>
<p dir="auto">No I didn’t since I know the archives are good when used with PKUNZIP. However I will and I’ll send one to you as well. I’ll try to do that tomorrow.</p>
<p dir="auto">Barry</p>
]]></description><link>https://forums.powerarchiver.com/post/7527</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7527</guid><dc:creator><![CDATA[barryem]]></dc:creator><pubDate>Thu, 10 Feb 2005 22:25:00 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Thu, 10 Feb 2005 00:57:30 GMT]]></title><description><![CDATA[<p dir="auto">You can send us an example (smaller) so we can test it out: <a href="mailto:supportREMOEVE@conexware.com" target="_blank" rel="noopener noreferrer nofollow ugc">supportREMOEVE@conexware.com</a>. That way I will be able to tell you better what might be wrong. Actual zip support has not been changed noticably for a while.</p>
]]></description><link>https://forums.powerarchiver.com/post/7521</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7521</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 10 Feb 2005 00:57:30 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Thu, 10 Feb 2005 00:53:39 GMT]]></title><description><![CDATA[<p dir="auto">I just checked the pkzip version I used and it was 2.04g. I have 5.0 but somehow that laptop has the older version on it.</p>
<p dir="auto">A few small archives will unzip. The rest start to and unzip a file or two or even several and then stop saying there was an unexpected end of the zip and that it was probably just the first part of a spanned archive. But it isnt spanned and PKUNZIP 2.04g unzips it just fine.</p>
<p dir="auto">This isn’t a problem I can’t live with. I do have PKUNZIP. But it sure is going to be a hassle and I am sure I’ve never had this problem before and I’ve been using PA to unzip stuff from this laptop since I registered it a few years ago.</p>
<p dir="auto">I went back to some of my backups and tried them. One in particular that I keep handy because it has some stuff I refer to now and then and I’m sure PA has unzipped it before but now it doesn’t do it. I’m not sure how long it’s been since I’ve done it.</p>
<p dir="auto">For what it’s worth, PA is the only archiver I’ve had on either my XP or my Win98 machines for a few years so I’m really very sure it’s unzipped this file before with no problems.</p>
]]></description><link>https://forums.powerarchiver.com/post/7520</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7520</guid><dc:creator><![CDATA[barryem]]></dc:creator><pubDate>Thu, 10 Feb 2005 00:53:39 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Thu, 10 Feb 2005 00:04:11 GMT]]></title><description><![CDATA[<p dir="auto">PA supports only pkzip 2.04g and higher specs. Long time ago, PkZip used implode method which is not supported by PA, nor I think it ever was.</p>
<p dir="auto">I think you might still be able to create implode zip archives with some pkzip utilities but I am not sure.</p>
<p dir="auto">sorry and thanks,</p>
]]></description><link>https://forums.powerarchiver.com/post/7517</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7517</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 10 Feb 2005 00:04:11 GMT</pubDate></item><item><title><![CDATA[Reply to PA 9.11.01 can&#x27;t unzip pkzip files on Wed, 09 Feb 2005 23:38:48 GMT]]></title><description><![CDATA[<p dir="auto">the latest version, though beta, is the 9.20.04, available through the update feature.</p>
]]></description><link>https://forums.powerarchiver.com/post/7516</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7516</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Wed, 09 Feb 2005 23:38:48 GMT</pubDate></item></channel></rss>
