<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[.zipx vs .zip 1and1 host cannot unzip .zipx]]></title><description><![CDATA[<p dir="auto">how can i zip files with .zip extension, my webhost 1and1 .com cannot unzip this file extension in webspace explorer.</p>
<p dir="auto">This has always the fastest way for me to get a site up and running.</p>
<p dir="auto">I have/had no problem now or in the past zipping these files untill I noticed it saves with .zipx extension instead of .zip</p>
<p dir="auto">If I try to upload all these in FTP PA will hang. so I really just need to zip, upload, extract</p>
<p dir="auto">Thanks for any help.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5341/zipx-vs-zip-1and1-host-cannot-unzip-zipx</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 02:38:53 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5341.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Jun 2015 18:16:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to .zipx vs .zip 1and1 host cannot unzip .zipx on Wed, 17 Jun 2015 14:31:55 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the help.<br />
I made a profile so I can use it both ways.<br />
by default is set to .zip.</p>
]]></description><link>https://forums.powerarchiver.com/post/32333</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32333</guid><dc:creator><![CDATA[Mr_Scary]]></dc:creator><pubDate>Wed, 17 Jun 2015 14:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to .zipx vs .zip 1and1 host cannot unzip .zipx on Tue, 16 Jun 2015 21:26:05 GMT]]></title><description><![CDATA[<p dir="auto">we should set this to default :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/32332</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32332</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 16 Jun 2015 21:26:05 GMT</pubDate></item><item><title><![CDATA[Reply to .zipx vs .zip 1and1 host cannot unzip .zipx on Tue, 16 Jun 2015 11:50:40 GMT]]></title><description><![CDATA[<p dir="auto">big up Richard! :)</p>
]]></description><link>https://forums.powerarchiver.com/post/32330</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32330</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Tue, 16 Jun 2015 11:50:40 GMT</pubDate></item><item><title><![CDATA[Reply to .zipx vs .zip 1and1 host cannot unzip .zipx on Mon, 15 Jun 2015 21:19:21 GMT]]></title><description><![CDATA[<p dir="auto">WOW, thanks. that was easy…</p>
]]></description><link>https://forums.powerarchiver.com/post/32329</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32329</guid><dc:creator><![CDATA[Mr_Scary]]></dc:creator><pubDate>Mon, 15 Jun 2015 21:19:21 GMT</pubDate></item><item><title><![CDATA[Reply to .zipx vs .zip 1and1 host cannot unzip .zipx on Mon, 15 Jun 2015 20:45:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mr_scary" aria-label="Profile: Mr_Scary">@<bdi>Mr_Scary</bdi></a>:</p>
<p dir="auto">1. Open PowerArchiver<br />
2. ‘Options’<br />
3. ‘Configuration’<br />
4. ‘Compression Profiles’ , select the Default for Zip.</p>
<p dir="auto">Within that change the ‘method’ from ‘Optimized’ to ‘Deflate’ and press ‘Ok’</p>
]]></description><link>https://forums.powerarchiver.com/post/32328</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32328</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Mon, 15 Jun 2015 20:45:34 GMT</pubDate></item></channel></rss>
