<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Office Security - Shell Extensions]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">Can you add a new sub group called ‘Power Archiver Office/PDF Security’ with the options;</p>
<ol>
<li>Office Encrypt</li>
<li>Office Decrypt</li>
<li>Office Sign</li>
<li>Office Verify</li>
<li>PDF Encrypt &amp; Sign</li>
</ol>
<p dir="auto">Provide the ability for it to be split as you do with Backup/FTP/Burner etc.</p>
<p dir="auto">I am liking the ability to Encrypt office files without having to convert it into a container. However, I have to go into the PA Encryption Suite every time to do it.</p>
<p dir="auto">It would still be nice to have ‘Office Wipe File’ option using the wipe facility you have for old temp files.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5302/office-security-shell-extensions</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 00:46:21 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5302.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Mar 2015 12:04:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Office Security - Shell Extensions on Mon, 16 Mar 2015 09:51:49 GMT]]></title><description><![CDATA[<p dir="auto">Cant wait, there are so many new features available but you have to search for them or launch a separate application. So some users are not always aware of them.</p>
]]></description><link>https://forums.powerarchiver.com/post/31977</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31977</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Mon, 16 Mar 2015 09:51:49 GMT</pubDate></item><item><title><![CDATA[Reply to Office Security - Shell Extensions on Fri, 13 Mar 2015 04:57:12 GMT]]></title><description><![CDATA[<p dir="auto">these things are not (yet) exposed for normal user, next major version, we will add it.</p>
<p dir="auto">We will likely add another submenu for Encryption since there are so many encryption related features now.</p>
]]></description><link>https://forums.powerarchiver.com/post/31973</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31973</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 13 Mar 2015 04:57:12 GMT</pubDate></item><item><title><![CDATA[Reply to Office Security - Shell Extensions on Thu, 12 Mar 2015 13:13:19 GMT]]></title><description><![CDATA[<p dir="auto">I haven’t been using this. But it seems as if I should be. thanks for making this proposal.</p>
]]></description><link>https://forums.powerarchiver.com/post/31972</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31972</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Thu, 12 Mar 2015 13:13:19 GMT</pubDate></item><item><title><![CDATA[Reply to Office Security - Shell Extensions on Thu, 12 Mar 2015 13:09:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/socrates" aria-label="Profile: Socrates">@<bdi>Socrates</bdi></a>:</p>
<p dir="auto">This sounds like a nice option, if it is not difficult to implement.</p>
<p dir="auto">One question (with three parts): about office and pdf encryption (since I have never really used them). Does PA use the native Office and PDF encryption? If not, what <em>does</em> it use? Will recipients without PA be able to access them?</p>
<p dir="auto">So far testing it when you use the Office Encrypt you can use the Default or 2007+ encryption.</p>
<p dir="auto">Users were able to open the files and enter a password without the need for Powerarchiver.</p>
]]></description><link>https://forums.powerarchiver.com/post/31971</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31971</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Thu, 12 Mar 2015 13:09:16 GMT</pubDate></item><item><title><![CDATA[Reply to Office Security - Shell Extensions on Thu, 12 Mar 2015 13:04:24 GMT]]></title><description><![CDATA[<p dir="auto">This sounds like a nice option, if it is not difficult to implement.</p>
]]></description><link>https://forums.powerarchiver.com/post/31970</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31970</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Thu, 12 Mar 2015 13:04:24 GMT</pubDate></item></channel></rss>
