<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Shell Ext. - Creating SFX]]></title><description><![CDATA[<p dir="auto">Can you add a new option to Shell Ext. menu (for archives)<br />
e. g. “Create self-extracting archive + Options” ?</p>
<p dir="auto">It should work like standart “Create self-extracting zip”<br />
but before creating EXE<br />
it must show “PA SelfExtractor” dialog<br />
(like PA main wnd &gt; Actions menu &gt; Make EXE file")<br />
or SFX Wizard<br />
(tools menu &gt; SFX Wizard)</p>
<p dir="auto">As for me , Make EXE dialog is better then the Wizard<br />
But you can add an option to the Configuration Dialod<br />
so users can select what they want to use:<br />
dialog or Wizard</p>
]]></description><link>https://forums.powerarchiver.com/topic/530/shell-ext-creating-sfx</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 17:24:34 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/530.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Feb 2005 06:01:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Mon, 08 Aug 2005 17:14:45 GMT]]></title><description><![CDATA[<p dir="auto">Just came across this post, and I wasn’t confused at all:</p>
<ul>
<li>the current shell extension does not let you set any of the important options for a SFX like the <strong>Default “UnZip To” Folder</strong> which are possible in the interface driven method to create the EXE</li>
</ul>
<p dir="auto">I would definitely like to see this improvement in the shell extension to create SFX as well. Whatever default options are being used this way are things I would never actually use unless I was only ever creating and recreating the same exact SFX :rolleyes:.</p>
]]></description><link>https://forums.powerarchiver.com/post/9396</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/9396</guid><dc:creator><![CDATA[steje]]></dc:creator><pubDate>Mon, 08 Aug 2005 17:14:45 GMT</pubDate></item><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Wed, 16 Feb 2005 12:16:00 GMT]]></title><description><![CDATA[<p dir="auto">Yes</p>
<p dir="auto">With current “Create Self-Extracting zip/cab” option in shell extensions<br />
we can convert archives to sfx without setting up any options…</p>
]]></description><link>https://forums.powerarchiver.com/post/7556</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7556</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Wed, 16 Feb 2005 12:16:00 GMT</pubDate></item><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Wed, 16 Feb 2005 11:54:30 GMT]]></title><description><![CDATA[<p dir="auto">now i understand you want more advance features with the sfx shell extensions we already have avaliable.</p>
]]></description><link>https://forums.powerarchiver.com/post/7555</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7555</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 16 Feb 2005 11:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Wed, 16 Feb 2005 08:39:45 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, maybe I don’t understamd your reply properly…</p>
<p dir="auto">I want to be able to set advansed SFX options (like Overwrite options, default extraction directory, sfx caption etc) when creating EXE file with shell extensions…</p>
<p dir="auto">Thanks, :)</p>
]]></description><link>https://forums.powerarchiver.com/post/7554</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7554</guid><dc:creator><![CDATA[Serhiy]]></dc:creator><pubDate>Wed, 16 Feb 2005 08:39:45 GMT</pubDate></item><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Wed, 16 Feb 2005 07:59:40 GMT]]></title><description><![CDATA[<p dir="auto">at the moment if you come across a zip or cab file ythe shell extensions if selected will give you the option to creat a sfx file.</p>
<p dir="auto">what i think you want is to be able to sauy zip or cab in one go to a sfx file even if you don’t have a archive already</p>
]]></description><link>https://forums.powerarchiver.com/post/7553</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7553</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 16 Feb 2005 07:59:40 GMT</pubDate></item><item><title><![CDATA[Reply to Shell Ext. - Creating SFX on Wed, 09 Feb 2005 11:16:33 GMT]]></title><description><![CDATA[<p dir="auto">I support this idea ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/7509</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7509</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Wed, 09 Feb 2005 11:16:33 GMT</pubDate></item></channel></rss>
