<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Backup: Write directly to zip]]></title><description><![CDATA[<p dir="auto">In your help:</p>
<p dir="auto"><a href="http://www.powerarchiver.com/wiki/en:help:main:tools:using_backup" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/wiki/en:help:main:tools:using_backup</a></p>
<p dir="auto">it has an item:</p>
<p dir="auto">Write directly into Zip - writes directly into backup archive (without the use of a temporary folder).</p>
<p dir="auto">Where is that?</p>
]]></description><link>https://forums.powerarchiver.com/topic/5283/backup-write-directly-to-zip</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 08:42:33 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5283.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Jan 2015 08:52:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Backup: Write directly to zip on Mon, 30 Mar 2015 15:30:47 GMT]]></title><description><![CDATA[<p dir="auto">this has been improved, lets check it out:<br />
<a href="http://www.powerarchiver.com/test/release15/powarc150106.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.powerarchiver.com/test/release15/powarc150106.exe</a></p>
]]></description><link>https://forums.powerarchiver.com/post/32058</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/32058</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 30 Mar 2015 15:30:47 GMT</pubDate></item><item><title><![CDATA[Reply to Backup: Write directly to zip on Mon, 26 Jan 2015 12:20:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alycat" aria-label="Profile: Alycat">@<bdi>Alycat</bdi></a>:</p>
<p dir="auto">Thanks.</p>
<p dir="auto">Talking about updating, is PA still developed in Delphi 7? :D</p>
<p dir="auto">Partially… backup and others are moved to XE2. Newer you go, slower and bigger it is.</p>
]]></description><link>https://forums.powerarchiver.com/post/31897</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31897</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 26 Jan 2015 12:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to Backup: Write directly to zip on Mon, 26 Jan 2015 02:36:33 GMT]]></title><description><![CDATA[<p dir="auto">Thanks.</p>
]]></description><link>https://forums.powerarchiver.com/post/31895</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31895</guid><dc:creator><![CDATA[Alycat]]></dc:creator><pubDate>Mon, 26 Jan 2015 02:36:33 GMT</pubDate></item><item><title><![CDATA[Reply to Backup: Write directly to zip on Sun, 25 Jan 2015 21:41:15 GMT]]></title><description><![CDATA[<p dir="auto">thanks luxor and alycat… i have updated this in help.</p>
]]></description><link>https://forums.powerarchiver.com/post/31894</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31894</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 25 Jan 2015 21:41:15 GMT</pubDate></item><item><title><![CDATA[Reply to Backup: Write directly to zip on Sat, 24 Jan 2015 23:40:53 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, will get that a go and see if it fixes my other problem, about hanging at the end of a backup.</p>
]]></description><link>https://forums.powerarchiver.com/post/31889</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31889</guid><dc:creator><![CDATA[Alycat]]></dc:creator><pubDate>Sat, 24 Jan 2015 23:40:53 GMT</pubDate></item><item><title><![CDATA[Reply to Backup: Write directly to zip on Sat, 24 Jan 2015 11:57:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi Alycat.</p>
<p dir="auto">I believe this is the option you are looking for.<br />
<img src="/uploads/_imported_attachments/attachment_p_33351_0_currentfolder.png" alt="attachment_p_33351_0_currentfolder.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/31884</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31884</guid><dc:creator><![CDATA[Luxor]]></dc:creator><pubDate>Sat, 24 Jan 2015 11:57:45 GMT</pubDate></item></channel></rss>
