<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extract EXE &amp; MSI]]></title><description><![CDATA[<p dir="auto">It would be nice to exe’s and MSI’s.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5155/extract-exe-msi</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Apr 2026 09:02:59 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5155.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Jul 2014 18:40:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extract EXE &amp; MSI on Tue, 15 Jul 2014 07:51:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/iampedro" aria-label="Profile: iampedro">@<bdi>iampedro</bdi></a>:</p>
<p dir="auto">We can do it just you first have to open it in PA is there an option to right click on an exe/msi and say extract to or extract just like zip’s or other compress files?</p>
<p dir="auto">yes, that already exists in PA 2013… try it on PA setup - extract exe, and then MSI in it as well.</p>
<p dir="auto">If it does not auto-detect some exe’s (all MSI’s should work), then send us the link (email?) and we will add support for those SFX’s.</p>
]]></description><link>https://forums.powerarchiver.com/post/31023</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31023</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 15 Jul 2014 07:51:06 GMT</pubDate></item><item><title><![CDATA[Reply to Extract EXE &amp; MSI on Tue, 15 Jul 2014 03:02:09 GMT]]></title><description><![CDATA[<p dir="auto">We can do it just you first have to open it in PA is there an option to right click on an exe/msi and say extract to or extract just like zip’s or other compress files?</p>
]]></description><link>https://forums.powerarchiver.com/post/31022</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31022</guid><dc:creator><![CDATA[iampedro]]></dc:creator><pubDate>Tue, 15 Jul 2014 03:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Extract EXE &amp; MSI on Mon, 14 Jul 2014 20:47:59 GMT]]></title><description><![CDATA[<p dir="auto">(installer’s and SFX’s)</p>
]]></description><link>https://forums.powerarchiver.com/post/31021</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31021</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 14 Jul 2014 20:47:59 GMT</pubDate></item><item><title><![CDATA[Reply to Extract EXE &amp; MSI on Mon, 14 Jul 2014 20:47:44 GMT]]></title><description><![CDATA[<p dir="auto">how do you mean? You can do that for a while? Maybe you tried with some that are not supported? If so, email us a link to the file and we will see if we can add support!</p>
]]></description><link>https://forums.powerarchiver.com/post/31020</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/31020</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 14 Jul 2014 20:47:44 GMT</pubDate></item></channel></rss>
