<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness]]></title><description><![CDATA[<p dir="auto">When I double click on a xxx.tar.gz file PA opens but I don’t get to see what’s in the file at all.</p>
<p dir="auto">PA right click Test seems to work but I have to respond to a UAC prompt first.</p>
<p dir="auto">PA right click Extract Here does nothing and again I have to respond to a UAC prompt first.</p>
<p dir="auto">PA right click Extract to archivename\ just creates an empty directory after I respond to a UAC prompt.</p>
<p dir="auto">I’ve got to go now.<br />
I should be able to investigate further over the weekend if you need me to.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5116/pa-14-05-01-win7-x64-tar-gz-weirdness</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 19:26:14 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5116.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 17 Apr 2014 14:55:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Wed, 30 Apr 2014 22:52:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mili" aria-label="Profile: Mili">@<bdi>Mili</bdi></a>:</p>
<p dir="auto">please Try with latest release:</p>
<p dir="auto"><a href="http://dl.patchbeam.com/conexware/files/powerarchiver/powarc140504int.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://dl.patchbeam.com/conexware/files/powerarchiver/powarc140504int.exe</a></p>
<p dir="auto">Thanks.</p>
<p dir="auto">That seems to work perfectly.<br />
No weird temp file names.</p>
]]></description><link>https://forums.powerarchiver.com/post/30916</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30916</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Wed, 30 Apr 2014 22:52:39 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Wed, 30 Apr 2014 18:01:02 GMT]]></title><description><![CDATA[<p dir="auto">please Try with latest release:</p>
]]></description><link>https://forums.powerarchiver.com/post/30913</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30913</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Wed, 30 Apr 2014 18:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Mon, 28 Apr 2014 01:08:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">seems like crazy temp file naming… interesting. thanks. Check the junction issue as well, should be fixed in this release.</p>
<p dir="auto">Yes a little session with sysinternals procmon shows it does appear to be creating a temp file with that weird name.</p>
]]></description><link>https://forums.powerarchiver.com/post/30884</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30884</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Mon, 28 Apr 2014 01:08:01 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Mon, 28 Apr 2014 00:54:59 GMT]]></title><description><![CDATA[<p dir="auto">thank you for reporting it :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/30883</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30883</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 28 Apr 2014 00:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Mon, 28 Apr 2014 00:52:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Yes it is.</p>
<p dir="auto">Thank you Thank you.<br />
:):):)</p>
]]></description><link>https://forums.powerarchiver.com/post/30882</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30882</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Mon, 28 Apr 2014 00:52:06 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Mon, 28 Apr 2014 00:19:01 GMT]]></title><description><![CDATA[<p dir="auto">seems like crazy temp file naming… interesting. thanks. Check the junction issue as well, should be fixed in this release.</p>
]]></description><link>https://forums.powerarchiver.com/post/30880</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30880</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 28 Apr 2014 00:19:01 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Mon, 28 Apr 2014 00:06:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">Here is updated build with fix for this issue:<br />
<a href="http://powerarchiver.com/test/release13/powarc140503int.exe" target="_blank" rel="noopener noreferrer nofollow ugc">http://powerarchiver.com/test/release13/powarc140503int.exe</a></p>
<p dir="auto">Please check it out and let us know if the issue still exists for you, thanks!</p>
<p dir="auto">Quick test seems to work fine but possible corruption or weird temp file name is shown when testing .tar.gz files.<br />
<img src="/uploads/_imported_attachments/attachment_p_32179_0_paimage2.png" alt="attachment_p_32179_0_paimage2.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/30879</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30879</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Mon, 28 Apr 2014 00:06:49 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Sun, 27 Apr 2014 23:47:15 GMT]]></title><description><![CDATA[<p dir="auto">Here is updated build with fix for this issue:<br />
]]></description><link>https://forums.powerarchiver.com/post/30878</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30878</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 27 Apr 2014 23:47:15 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Thu, 17 Apr 2014 17:21:40 GMT]]></title><description><![CDATA[<p dir="auto">logged in.<br />
Thanks for reporting Brian and have a great weekend!</p>
]]></description><link>https://forums.powerarchiver.com/post/30830</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30830</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Thu, 17 Apr 2014 17:21:40 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Thu, 17 Apr 2014 15:12:56 GMT]]></title><description><![CDATA[<p dir="auto">thanks, they should work…. will check it out.</p>
]]></description><link>https://forums.powerarchiver.com/post/30828</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30828</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 17 Apr 2014 15:12:56 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Thu, 17 Apr 2014 15:08:20 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://the.earth.li/~sgtatham/putty/latest/putty-0.63.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">http://the.earth.li/~sgtatham/putty/latest/putty-0.63.tar.gz</a></p>
<p dir="auto"><a href="http://forum.astro.keele.ac.uk:8080/nugrid/copy_of_releases-and-software-downloads/se-library-release/se-1.2.1.tar.gz" target="_blank" rel="noopener noreferrer nofollow ugc">http://forum.astro.keele.ac.uk:8080/nugrid/copy_of_releases-and-software-downloads/se-library-release/se-1.2.1.tar.gz</a></p>
]]></description><link>https://forums.powerarchiver.com/post/30827</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30827</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Thu, 17 Apr 2014 15:08:20 GMT</pubDate></item><item><title><![CDATA[Reply to PA 14.05.01 + Win7 x64&#x5C;. .tar.gz weirdness on Thu, 17 Apr 2014 15:00:17 GMT]]></title><description><![CDATA[<p dir="auto">can you send us that file? it does not happen with every .gz file, i tried one quickly here and it was working as expected. Thanks"</p>
]]></description><link>https://forums.powerarchiver.com/post/30826</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30826</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 17 Apr 2014 15:00:17 GMT</pubDate></item></channel></rss>
