<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Tray Notification icon keeps disabling itself.]]></title><description><![CDATA[<p dir="auto">Every now and then, perhaps when PowerArchiver 2013 updates itself, but I’m not certain what triggers it, the PowerArchiver icon in the system tray area disables itself and I have to go into Customize Notification Area Icons in Control Panel and change the PASTARTER.EXE icon back to “show icon and notifications” and reposition it back to where I want it in the tray area. Other programs don’t seem to have this problem with their icons.</p>
<p dir="auto">I’m using PowerArchiver 14.05.01 but several previous versions have had the same problem.</p>
<p dir="auto">I’m running under Windows 7 Ultimate 64 bit.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5112/tray-notification-icon-keeps-disabling-itself</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 09:17:21 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5112.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Apr 2014 23:06:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Tray Notification icon keeps disabling itself. on Thu, 15 May 2014 00:51:17 GMT]]></title><description><![CDATA[<p dir="auto">I have now seen this happen to another program when I updated it. So you are correct - it isn’t a PowerArchiver problem.</p>
]]></description><link>https://forums.powerarchiver.com/post/30960</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30960</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Thu, 15 May 2014 00:51:17 GMT</pubDate></item><item><title><![CDATA[Reply to Tray Notification icon keeps disabling itself. on Wed, 09 Apr 2014 18:52:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/moles42" aria-label="Profile: moles42">@<bdi>moles42</bdi></a>:</p>
<p dir="auto">I’ve not encountered it with PA as such but have certainly seen it happen with other programs I’ve used but I’m no nearer to finding a cause…:(</p>
<p dir="auto">I’ve seen other icons randomly never appearing even though the software seems to be running but logging out and back in again fixes those. PowerArchiver’s icon seems unique in that it actually gets set to “Only show notifications” when I want “Show icon and notifications”.</p>
]]></description><link>https://forums.powerarchiver.com/post/30817</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30817</guid><dc:creator><![CDATA[Brian Gregory]]></dc:creator><pubDate>Wed, 09 Apr 2014 18:52:34 GMT</pubDate></item><item><title><![CDATA[Reply to Tray Notification icon keeps disabling itself. on Wed, 09 Apr 2014 08:48:39 GMT]]></title><description><![CDATA[<p dir="auto">I am pretty sure it is Windows doing it, we certainly dont have any code made for that.</p>
<p dir="auto">Maybe the update triggers Windows to send it back as default behaviour?</p>
]]></description><link>https://forums.powerarchiver.com/post/30816</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30816</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 09 Apr 2014 08:48:39 GMT</pubDate></item><item><title><![CDATA[Reply to Tray Notification icon keeps disabling itself. on Wed, 09 Apr 2014 06:54:13 GMT]]></title><description><![CDATA[<p dir="auto">I’ve not encountered it with PA as such but have certainly seen it happen with other programs I’ve used but I’m no nearer to finding a cause…:(</p>
]]></description><link>https://forums.powerarchiver.com/post/30815</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30815</guid><dc:creator><![CDATA[moles42]]></dc:creator><pubDate>Wed, 09 Apr 2014 06:54:13 GMT</pubDate></item></channel></rss>
