<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compress with FTP (to optional sites) from shell]]></title><description><![CDATA[<p dir="auto">I thought this was already a feature. If so, I would <strong>definitely</strong> like it reinstated.</p>
<p dir="auto">If not, I would like it added as a feature, preferably as soon as possible.</p>
<p dir="auto">Currently from the shell, if you use selected compress and ftp, user cannot choose to WHICH ftp site the file should be uploaded.</p>
<p dir="auto">The user CAN selected the desired site, but only if she does not first compress the file(s).</p>
<p dir="auto">I want to be able to compress the files from the shell and THEN choose the destination FTP site.</p>
<p dir="auto">And while I am at it, I would encourage you to include an option within profiles to specify the default folder not only on the server side (which you now do), but the default folder on the computer side.</p>
]]></description><link>https://forums.powerarchiver.com/topic/5032/compress-with-ftp-to-optional-sites-from-shell</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 12:54:59 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/5032.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Jul 2013 01:05:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Thu, 15 Aug 2013 14:29:59 GMT]]></title><description><![CDATA[<p dir="auto">Thanks. It’s there now, albeit in a slightly different form.</p>
<p dir="auto">Very helpful.</p>
]]></description><link>https://forums.powerarchiver.com/post/30408</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30408</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Thu, 15 Aug 2013 14:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Wed, 31 Jul 2013 21:48:13 GMT]]></title><description><![CDATA[<p dir="auto">ok, i wrote it into the feature wishlist…</p>
]]></description><link>https://forums.powerarchiver.com/post/30333</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30333</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 31 Jul 2013 21:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Wed, 31 Jul 2013 14:03:24 GMT]]></title><description><![CDATA[<p dir="auto">Yes.</p>
<p dir="auto">Sorry that I was unclear.</p>
]]></description><link>https://forums.powerarchiver.com/post/30332</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30332</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Wed, 31 Jul 2013 14:03:24 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Wed, 31 Jul 2013 13:52:06 GMT]]></title><description><![CDATA[<p dir="auto">aha, so compress and ftp to &gt; profile</p>
]]></description><link>https://forums.powerarchiver.com/post/30331</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30331</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 31 Jul 2013 13:52:06 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Wed, 31 Jul 2013 09:47:49 GMT]]></title><description><![CDATA[<p dir="auto">The option to compress and FTP the file is there. But it does not include the option to chose WHICH FTP profile to use.</p>
<p dir="auto">The option to choose profiles IS available, but only if I do not first Compress it.</p>
]]></description><link>https://forums.powerarchiver.com/post/30330</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30330</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Wed, 31 Jul 2013 09:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with FTP (to optional sites) from shell on Wed, 31 Jul 2013 05:42:58 GMT]]></title><description><![CDATA[<p dir="auto">so you select an zip file and you don get ftp option? Check in Shell Extensions, it should be there in Config… maybe when you uninstalled recently, you lost the option?</p>
]]></description><link>https://forums.powerarchiver.com/post/30328</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/30328</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 31 Jul 2013 05:42:58 GMT</pubDate></item></channel></rss>
