<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[&quot;Hide filename&quot; not available under encrypt 7zip format]]></title><description><![CDATA[<p dir="auto">In the past I used 7ZIP and was able to hide filenames during encryption of an archive. I bought PA (13.02.02 09/2012) believing that was also possible, reading the manual pages and online help. But when I select Encrypt, and then 7ZIP format, I cannot see “hide filename” as an option. It only exists if you choose PAE as an output format.</p>
<p dir="auto">Bug? Its very helpful to hide the filenames as it clearly makes it harder to decrypt if you have no clue as to possible contents of each sub-file.</p>
<p dir="auto">Mike<br />
BTW - the captcha requirement on every post … a bit excessive, and some of them are pretty hard to read as a human!</p>
]]></description><link>https://forums.powerarchiver.com/topic/4877/hide-filename-not-available-under-encrypt-7zip-format</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 22:28:32 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4877.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Jan 2013 19:53:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Tue, 22 Jan 2013 22:51:16 GMT]]></title><description><![CDATA[<p dir="auto">Added Encrypt Filenames option to the latest update, Drag and Drop window… please update via patchbeam and let us know. Thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/29571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29571</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 22 Jan 2013 22:51:16 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Mon, 07 Jan 2013 21:51:11 GMT]]></title><description><![CDATA[<p dir="auto">Wow, I’ve never even seen the Drag and Drop screen before. I guess we all have our own way of using our tools :)</p>
<p dir="auto">The dialogue in the second screenshot was the one I assumed you were using.</p>
]]></description><link>https://forums.powerarchiver.com/post/29537</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29537</guid><dc:creator><![CDATA[iDunk]]></dc:creator><pubDate>Mon, 07 Jan 2013 21:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Mon, 07 Jan 2013 13:51:43 GMT]]></title><description><![CDATA[<p dir="auto">great finds Morph!<br />
logging them in :)</p>
]]></description><link>https://forums.powerarchiver.com/post/29535</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29535</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 07 Jan 2013 13:51:43 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Mon, 07 Jan 2013 12:54:58 GMT]]></title><description><![CDATA[<p dir="auto">idunk - thanks again - your suggestion works.</p>
<p dir="auto">Mili - your scenarios are correct, but here are two where “encrypt filenames” is not available, though it should be.</p>
<p dir="auto">Create a new 7ZIP empty archive, without encryption.<br />
Drag a file into the window, the attached popup appears. Select encrypt - filename option not available.</p>
<p dir="auto">Create a 7ZIP unencrypted file with some content (a single file) or open an existing 7ZIP file.<br />
Select Encrypt from Tools menu. Attached pops up - select 7ZIP, Encrypt AES - filename option again not available. This is the more common situation for me where I want to simply encrypt some archives and not others, that have been previously created.</p>
<p dir="auto"><img src="/uploads/_imported_attachments/attachment_p_30258_0_dragged.jpg" alt="attachment_p_30258_0_dragged.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/_imported_attachments/attachment_p_30258_1_existing-7zip.jpg" alt="attachment_p_30258_1_existing-7zip.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/29534</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29534</guid><dc:creator><![CDATA[Morph]]></dc:creator><pubDate>Mon, 07 Jan 2013 12:54:58 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Mon, 07 Jan 2013 09:35:18 GMT]]></title><description><![CDATA[<p dir="auto">Here is a test screenshot of 13.02.02 creating a new 7Z archive through main PA.<br />
As you can see the “Encrypt Filenames” option is available and can be checked when encryption is selected.<br />
I am assuming that you might have selected the Zip format which is why the “Encrypt Filenames” option is not available.<br />
When entering the name of your archive, please select the 7Zip format in that same dialogue just below the file name field and everything should appear as in the screenshot.</p>
<p dir="auto">:)<br />
<img src="/uploads/_imported_attachments/attachment_p_30257_0_ef.png" alt="attachment_p_30257_0_ef.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/29533</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29533</guid><dc:creator><![CDATA[Mili]]></dc:creator><pubDate>Mon, 07 Jan 2013 09:35:18 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Sun, 06 Jan 2013 18:29:22 GMT]]></title><description><![CDATA[<p dir="auto">No problem. In case you want to compress and encrypt files or folders, there is the right-click method (also available from within PA main window), and there is the “New” &gt; “New archive…” method, with a different dialogue, where “Encrypt filenames” is also available.</p>
<p dir="auto">“Encrypt files” is mainly useful if you want to encrypt files which already are archives. However, it would be useful to have the option to encrypt filenames in this dialogue, too.</p>
]]></description><link>https://forums.powerarchiver.com/post/29532</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29532</guid><dc:creator><![CDATA[iDunk]]></dc:creator><pubDate>Sun, 06 Jan 2013 18:29:22 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Sun, 06 Jan 2013 16:58:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/idunk" aria-label="Profile: iDunk">@<bdi>iDunk</bdi></a>:</p>
<p dir="auto">Right click a file or files &gt; “Compress To…” &gt; “Compress With Options…” &gt; Select format: “7-ZIP” &gt; Encryption: “AES 256-bit” &gt; check “Encrypt filenames”.</p>
<p dir="auto">The “Encrypt Files” dialogue in the main program window should probably be updated to include this option. I assume that is what you are using.</p>
<p dir="auto">Thank you - I can confirm this method works as you describe. And yes, I would certainly appreciate the option being included in the main program, which is what I tend to use.</p>
]]></description><link>https://forums.powerarchiver.com/post/29531</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29531</guid><dc:creator><![CDATA[Morph]]></dc:creator><pubDate>Sun, 06 Jan 2013 16:58:20 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Sun, 06 Jan 2013 16:53:35 GMT]]></title><description><![CDATA[<p dir="auto">thank you, we will check it out…</p>
]]></description><link>https://forums.powerarchiver.com/post/29530</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29530</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 06 Jan 2013 16:53:35 GMT</pubDate></item><item><title><![CDATA[Reply to &quot;Hide filename&quot; not available under encrypt 7zip format on Sat, 05 Jan 2013 23:19:19 GMT]]></title><description><![CDATA[<p dir="auto">Right click a file or files &gt; “Compress To…” &gt; “Compress With Options…” &gt; Select format: “7-ZIP” &gt; Encryption: “AES 256-bit” &gt; check “Encrypt filenames”.</p>
]]></description><link>https://forums.powerarchiver.com/post/29527</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/29527</guid><dc:creator><![CDATA[iDunk]]></dc:creator><pubDate>Sat, 05 Jan 2013 23:19:19 GMT</pubDate></item></channel></rss>
