<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PA Toolkit backup using standalon DVD burner]]></title><description><![CDATA[<p dir="auto">I am using the standalone DVD burner in PA Toolkit to backup photographs to DVD. They are in folders by year and then month. I am using “add folder” until it gets to correct amount for the DVD (In this case 8.5GB). Last night I added one folder and there was room for another. When I did “Add folder” again the ones already there disappeared although the amount added was correct for all folders added. After I had burned it, only the original folder seemed to be on the DVD. Do you have any suggestions please? It has happened before but I thought I had made a mistake.<br />
Many thanks<br />
Gerry</p>
]]></description><link>https://forums.powerarchiver.com/topic/4725/pa-toolkit-backup-using-standalon-dvd-burner</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 14:06:01 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4725.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 May 2012 19:44:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Tue, 29 May 2012 09:39:13 GMT]]></title><description><![CDATA[<p dir="auto">great!</p>
]]></description><link>https://forums.powerarchiver.com/post/28742</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28742</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 29 May 2012 09:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Tue, 29 May 2012 09:26:46 GMT]]></title><description><![CDATA[<p dir="auto">Thanks again SPWolf. That worked a treat.</p>
<p dir="auto">Kind regards</p>
<p dir="auto">Gerry</p>
]]></description><link>https://forums.powerarchiver.com/post/28741</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28741</guid><dc:creator><![CDATA[Gerry Robinson]]></dc:creator><pubDate>Tue, 29 May 2012 09:26:46 GMT</pubDate></item><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Mon, 21 May 2012 14:24:48 GMT]]></title><description><![CDATA[<p dir="auto">Many thanks spwolf. Will give that a go.</p>
<p dir="auto">Kind reghards</p>
]]></description><link>https://forums.powerarchiver.com/post/28571</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28571</guid><dc:creator><![CDATA[Gerry Robinson]]></dc:creator><pubDate>Mon, 21 May 2012 14:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Mon, 21 May 2012 07:31:50 GMT]]></title><description><![CDATA[<p dir="auto">Use last session and Create Multi Session disc need to be checked in PA Burner?</p>
]]></description><link>https://forums.powerarchiver.com/post/28565</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28565</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 21 May 2012 07:31:50 GMT</pubDate></item><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Sat, 19 May 2012 22:35:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sir Richard.<br />
Thanks for reply. Here are the details as req.<br />
Windows 7 Home Premium. SP1 (updates up to date!)<br />
Processor Intel® Core™2 CPU 6320 @ 1.86GHz 1.87GHz<br />
Ram 3.377GB<br />
System type 32 bit<br />
Workgroup workgroup</p>
<p dir="auto">I have PA version Toolbox, just purchased.<br />
Thanks</p>
]]></description><link>https://forums.powerarchiver.com/post/28564</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28564</guid><dc:creator><![CDATA[Gerry Robinson]]></dc:creator><pubDate>Sat, 19 May 2012 22:35:18 GMT</pubDate></item><item><title><![CDATA[Reply to PA Toolkit backup using standalon DVD burner on Sat, 19 May 2012 19:56:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi Gerry,</p>
<p dir="auto">Can you clarify your system specs please? If you are unsure how to do this goto your Desktop and right click on the Computer Icon. called “My Computer” or on windows 7 “Computer”</p>
<p dir="auto">A page should appear this should provide you with the System CPU, RAM and Operating System with Service Pack Number if installed.</p>
<p dir="auto">The more information you can provide the easier it is for us to try and replicate this process and figure out whats going on.</p>
]]></description><link>https://forums.powerarchiver.com/post/28562</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/28562</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Sat, 19 May 2012 19:56:06 GMT</pubDate></item></channel></rss>
