<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Power archiver insult me with a big error message….]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I m using power archiver v6.0.0.5 (free version) with windows2000 sp4.<br />
All my computers have the same hardware configuration and are masterized thank to an image file (.gho) so they are perfectly identical.<br />
Unhappy i have in 25% of cases the following error message when i launch power archiver.</p>
<p dir="auto">“Access violation at adress 00054568B in module ‘POWERARC.EXE’. Read in adress 00000000”</p>
<p dir="auto">After this message power archiver is running but without any icons in the toolsbar.</p>
<p dir="auto">Does someone can help me about this problem, that will be very cool.</p>
<p dir="auto">thx,</p>
<p dir="auto">Yannis</p>
]]></description><link>https://forums.powerarchiver.com/topic/456/power-archiver-insult-me-with-a-big-error-message</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 19:03:39 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/456.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Jan 2005 08:56:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Power archiver insult me with a big error message…. on Mon, 17 Jan 2005 16:36:05 GMT]]></title><description><![CDATA[<p dir="auto">In fact it s not a pb on software or os but an ntuser.dat corruption. :rolleyes:<br />
Indeed my users was unable to update or add key in their registry without replace their ntuser.dat with a blank one.</p>
<p dir="auto">Thx davidsplash &amp; manuangi for your help</p>
<p dir="auto">yannis</p>
]]></description><link>https://forums.powerarchiver.com/post/7217</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7217</guid><dc:creator><![CDATA[yannis]]></dc:creator><pubDate>Mon, 17 Jan 2005 16:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to Power archiver insult me with a big error message…. on Mon, 17 Jan 2005 12:47:07 GMT]]></title><description><![CDATA[<p dir="auto">that version is definqately not supported. I would move on up to the latest version of pa. I have been using pa ever scince it was free right up to its present status shareware. I have found no problems in paying for the sharware version. It does more things than winzip and support for it is second to none. I would recxommend upgrading its only a mere £25 and is well worth it.</p>
]]></description><link>https://forums.powerarchiver.com/post/7216</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7216</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Mon, 17 Jan 2005 12:47:07 GMT</pubDate></item><item><title><![CDATA[Reply to Power archiver insult me with a big error message…. on Mon, 17 Jan 2005 09:38:24 GMT]]></title><description><![CDATA[<p dir="auto">I never used that version…too old…and maybe buggy, I dunno…<br />
you can’t expect devs to still support that, I believe…</p>
<p dir="auto">anyway, there may be some incompatibilities with the operating system or other sw you have installed on your machines…</p>
<p dir="auto">if you want to be sure about that, what you can do is, on a clean installed machine, put on PA6 and check whether it works. if id does, install a new software you need, then check again…an so on, you may well find the culprit!</p>
]]></description><link>https://forums.powerarchiver.com/post/7210</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7210</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Mon, 17 Jan 2005 09:38:24 GMT</pubDate></item></channel></rss>
