<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Uha format]]></title><description><![CDATA[<p dir="auto">would love to have this format added to pa. so i can make self extracting sfx archives</p>
<p dir="auto">compresion ration better than 7zip</p>
]]></description><link>https://forums.powerarchiver.com/topic/4478/uha-format</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 01:49:34 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4478.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Jun 2011 11:55:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Uha format on Tue, 07 Jun 2011 06:39:47 GMT]]></title><description><![CDATA[<p dir="auto">well if the makers of powerarchiver could tell us how to add commandline versions of archivers to the plugin system i would be more than greatfull as it has to be specific to pa</p>
]]></description><link>https://forums.powerarchiver.com/post/26509</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26509</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Tue, 07 Jun 2011 06:39:47 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Mon, 06 Jun 2011 07:18:37 GMT]]></title><description><![CDATA[<p dir="auto">I wish format methods wernt so scattered. Why cant we just upgrade on formats instead of creating new ones… I know why but it would be great to have cab, iso, 7zip &amp; paf. And if someone codes something great instead of creating say .rjw just merge the new method into whatever existing formats match its criteria</p>
]]></description><link>https://forums.powerarchiver.com/post/26506</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26506</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Mon, 06 Jun 2011 07:18:37 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Mon, 06 Jun 2011 00:12:18 GMT]]></title><description><![CDATA[<p dir="auto">we added a bunch of them in 2011… we will try adding only things that are used, as everything new that we add, adds complexity to PA.</p>
]]></description><link>https://forums.powerarchiver.com/post/26504</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26504</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 06 Jun 2011 00:12:18 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Sun, 05 Jun 2011 16:15:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a>:</p>
<p dir="auto">uha is dead format not developed for 6 years now.</p>
<p dir="auto">:) Indeed, Keep the old for Backward combatibility and include the New formats for Conversions to more dynamic and updated types.</p>
]]></description><link>https://forums.powerarchiver.com/post/26501</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26501</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Sun, 05 Jun 2011 16:15:47 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Sun, 05 Jun 2011 11:31:49 GMT]]></title><description><![CDATA[<p dir="auto">uha is dead format not developed for 6 years now.</p>
]]></description><link>https://forums.powerarchiver.com/post/26500</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26500</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 05 Jun 2011 11:31:49 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Sun, 05 Jun 2011 09:18:02 GMT]]></title><description><![CDATA[<p dir="auto">would it not be a great idea for powerachiver to have some sort of way of interacting with older formats via their command line programs using pa’s plugin format?</p>
]]></description><link>https://forums.powerarchiver.com/post/26499</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26499</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 05 Jun 2011 09:18:02 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Sun, 05 Jun 2011 09:16:02 GMT]]></title><description><![CDATA[<p dir="auto">people only stick with certain archivers cause of compatibility with certain archive formats. Uha give s you the best compression of any format.</p>
]]></description><link>https://forums.powerarchiver.com/post/26498</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26498</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Sun, 05 Jun 2011 09:16:02 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Fri, 03 Jun 2011 13:38:57 GMT]]></title><description><![CDATA[<p dir="auto">Having additional support for historic Formats is just as important as developing Future Technologies such as PAF.</p>
<p dir="auto">Evidently, the more PowerArchiver supports enables users to eventually “Convert” them over to newer more efficient types such as PA’s.</p>
]]></description><link>https://forums.powerarchiver.com/post/26484</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26484</guid><dc:creator><![CDATA[RJWaring]]></dc:creator><pubDate>Fri, 03 Jun 2011 13:38:57 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Fri, 03 Jun 2011 11:20:04 GMT]]></title><description><![CDATA[<p dir="auto">yes i did and what i was wanting is uha format for the now instead of waiting untill you decide on your new format details</p>
]]></description><link>https://forums.powerarchiver.com/post/26483</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26483</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Fri, 03 Jun 2011 11:20:04 GMT</pubDate></item><item><title><![CDATA[Reply to Uha format on Wed, 01 Jun 2011 14:24:34 GMT]]></title><description><![CDATA[<p dir="auto">didnt you see we are creating our own format? you will be fine with it :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/26469</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26469</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 01 Jun 2011 14:24:34 GMT</pubDate></item></channel></rss>
