<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Compress with options]]></title><description><![CDATA[<p dir="auto">I just noticed yesterday that “Compress with Options” is missing from the shell, even though I have checked the config setting “Display ‘Compress with Options’ item.”</p>
<p dir="auto">Maybe this was introduced in RC4. Or perhaps something made it disappear. If the latter, any ideas on how to get it back?</p>
<p dir="auto">15 minutes later. I discovered that I have to have “Compress to Zip” turned on to get “Compress with Option”. But I don’t really want compress to Zip, just compress to ZIPX.</p>
<p dir="auto">I can get around the problem by defining “Compress to Zip” as if it were “Compress to ZIPX.” But perhaps I shouldn’t have to.</p>
<p dir="auto">8 minutes after that. I also get both FTP and Compress and FTP as options in the shell, even though there is only one option in the Shell Extensions configuration screen: “FTP it.”</p>
]]></description><link>https://forums.powerarchiver.com/topic/4471/compress-with-options</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 08:37:44 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4471.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 May 2011 22:09:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Compress with options on Wed, 25 May 2011 15:59:16 GMT]]></title><description><![CDATA[<p dir="auto">Well, I don’t FTP so…</p>
<p dir="auto">However, I do feel that having compress options tied to formats is no longer necessary, if for no other reason than ZIP is probably not the most used any more.</p>
<p dir="auto">Comprees with options should be seperate.<br />
So should the associate PA with formats prompt (it activates when PA is NOT associated with ZIP).<br />
Maybe Gzip and Bzip without TAR (so can be used with single files)?</p>
]]></description><link>https://forums.powerarchiver.com/post/26422</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26422</guid><dc:creator><![CDATA[TBGBe]]></dc:creator><pubDate>Wed, 25 May 2011 15:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with options on Wed, 25 May 2011 13:04:58 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps that assumption holds for the majority of others. If so, then you should keep it the way it is.</p>
<p dir="auto">Me? I have other programs for FTPing. So I would only use the compress and FTP.</p>
<p dir="auto">And since I prefer a less cluttered list of options, I would rather have none, that one that I would never use.</p>
<p dir="auto">But that they reflect some idiosyncratic preference.</p>
]]></description><link>https://forums.powerarchiver.com/post/26421</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26421</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Wed, 25 May 2011 13:04:58 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with options on Wed, 25 May 2011 12:47:31 GMT]]></title><description><![CDATA[<p dir="auto">there is an difference:</p>
<ul>
<li>FTP It - sends any file to FTP, without compression</li>
<li>Compress and FTP - compresses the file and then sends it to FTP.</li>
</ul>
<p dir="auto">So assumption was that if you wanted any of FTP options, you would want them both.</p>
]]></description><link>https://forums.powerarchiver.com/post/26420</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26420</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 25 May 2011 12:47:31 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with options on Wed, 25 May 2011 10:17:53 GMT]]></title><description><![CDATA[<p dir="auto">I understand the concern. You might swamp users with relatively trivial options. Perhaps this is one of those cases.</p>
<p dir="auto">Two suggestions. (1) if you are going to pair options, you might want to find a way to let users know.</p>
<p dir="auto">I also get both FTP and Compress and FTP as options in the<br />
shell, even though there is only one option in the Shell<br />
<p dir="auto">(2) I would propose changing this. Given where these options appear, seems any FTP always involves “Compress and FTP.” So why not just the shorter “FTP it”?</p>
]]></description><link>https://forums.powerarchiver.com/post/26419</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26419</guid><dc:creator><![CDATA[Socrates]]></dc:creator><pubDate>Wed, 25 May 2011 10:17:53 GMT</pubDate></item><item><title><![CDATA[Reply to Compress with options on Wed, 25 May 2011 02:51:26 GMT]]></title><description><![CDATA[<p dir="auto">currently (and since start of times), we have some options tied to other options…</p>
<p dir="auto">basically so it would be easier to configure and less options to understand…</p>
<p dir="auto">should we change this?</p>
]]></description><link>https://forums.powerarchiver.com/post/26416</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26416</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Wed, 25 May 2011 02:51:26 GMT</pubDate></item></channel></rss>
