<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Another possible tar&#x2F;gz&#x2F;tgz problem]]></title><description><![CDATA[<p dir="auto">I tried opening a .tgz file in PA 12.00.41 via a webpage link directly, and I get a folder named “COROUTINE-1.0.tgz-1.tar” with no contents. However, if I download the file first instead of opening it directly, PA can open and deal with the file no problem.</p>
<p dir="auto">The webpage is: <a href="http://www.akira.ruc.dk/~keld/research/COROUTINE/" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.akira.ruc.dk/~keld/research/COROUTINE/</a></p>
<p dir="auto">The link is: <a href="http://www.akira.ruc.dk/~keld/research/COROUTINE/COROUTINE-1.0.tgz" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.akira.ruc.dk/~keld/research/COROUTINE/COROUTINE-1.0.tgz</a></p>
<p dir="auto">I’m not sure if this is really a problem with PA, something to do with how the link is setup on the webpage, a problem with Firefox 3.6.17, or just a problem on my system.</p>
<p dir="auto">I thought I’d mention it here just in case, but if it’s not something that can or should be addressed by PA, please just ignore the post.</p>
]]></description><link>https://forums.powerarchiver.com/topic/4458/another-possible-tar-gz-tgz-problem</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 19:20:05 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4458.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 May 2011 19:36:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Another possible tar&#x2F;gz&#x2F;tgz problem on Wed, 18 May 2011 06:27:58 GMT]]></title><description><![CDATA[<p dir="auto">one idea would be for power archiver to download the file in the background to a special temp folder for this purpose and once you close the archive to delete it.</p>
]]></description><link>https://forums.powerarchiver.com/post/26276</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26276</guid><dc:creator><![CDATA[davidsplash]]></dc:creator><pubDate>Wed, 18 May 2011 06:27:58 GMT</pubDate></item><item><title><![CDATA[Reply to Another possible tar&#x2F;gz&#x2F;tgz problem on Tue, 17 May 2011 00:53:16 GMT]]></title><description><![CDATA[<p dir="auto">it is indeed due to the naming in Firefox… It is actually server configuration problem, but I do believe that other browsers try to fix them on the fly.</p>
<p dir="auto">We will see if we can do anything about it… In Chrome it works fine, and in IE it renames it even worse.</p>
]]></description><link>https://forums.powerarchiver.com/post/26275</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26275</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Tue, 17 May 2011 00:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to Another possible tar&#x2F;gz&#x2F;tgz problem on Mon, 16 May 2011 23:54:36 GMT]]></title><description><![CDATA[<p dir="auto">Maybe this coroutine library will help squash a bug in PA, without even having to use them in your code!</p>
<p dir="auto">(Though I hope its just something with the link or Firefox).</p>
]]></description><link>https://forums.powerarchiver.com/post/26274</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26274</guid><dc:creator><![CDATA[mwb1100]]></dc:creator><pubDate>Mon, 16 May 2011 23:54:36 GMT</pubDate></item><item><title><![CDATA[Reply to Another possible tar&#x2F;gz&#x2F;tgz problem on Mon, 16 May 2011 20:44:33 GMT]]></title><description><![CDATA[<p dir="auto">coroutines are cool, used in our engines :-)</p>
]]></description><link>https://forums.powerarchiver.com/post/26271</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/26271</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Mon, 16 May 2011 20:44:33 GMT</pubDate></item></channel></rss>
