<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue]]></title><description><![CDATA[<p dir="auto">download the self extracting executable of 7zip, either the <a href="http://www.7-zip.org/dl/7z313.exe" target="_blank" rel="noopener noreferrer nofollow ugc">3.13</a> or the <a href="http://www.7-zip.org/dl/7z413b.exe" target="_blank" rel="noopener noreferrer nofollow ugc">4.13 beta</a>:</p>
<p dir="auto">then right-click on either file…PA’s menu won’t have any “extract to” voice, while WinR**'s has.</p>
<p dir="auto">how can that be? PA obviously can’t recognize the type of file…</p>
]]></description><link>https://forums.powerarchiver.com/topic/440/solved-a-check-for-self-extracting-zip-arj-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 21:40:14 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/440.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 08 Jan 2005 11:19:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 14:44:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuangi" aria-label="Profile: manuangi">@<bdi>manuangi</bdi></a>:</p>
<p dir="auto">by the way…I guess this option should be not modifiable, and set to check…</p>
<p dir="auto">I’m thinking of a reason why one could want it unchecked, but nothing cames to my mind…what do you think?</p>
<p dir="auto">Reason it is there is that in some cases, when you have large SFX archives, it will slow down your system when you just click on the file in Windows Explorer. So in certain cases, depending on what you do on your computer, you certainly might want it off.</p>
<p dir="auto">:-)</p>
<p dir="auto">Closing it.</p>
]]></description><link>https://forums.powerarchiver.com/post/7147</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7147</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sat, 08 Jan 2005 14:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 11:58:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manuangi" aria-label="Profile: manuangi">@<bdi>manuangi</bdi></a>:</p>
<p dir="auto">I had uncecked the “Check for self-extracting ZIP, ARJ…” option</p>
]]></description><link>https://forums.powerarchiver.com/post/7144</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7144</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 11:55:41 GMT]]></title><description><![CDATA[<p dir="auto">I’m a fool girl! :p</p>
<p dir="auto">It’s not any of a bug…it’s just that I had uncecked the “Check for self-extracting ZIP, ARJ…” option!!! :p</p>
<p dir="auto"><a class="plugin-mentions-group plugin-mentions-a" href="/groups/mods" aria-label="Profile: mods">@<bdi>mods</bdi></a>: you can lock this thread!</p>
]]></description><link>https://forums.powerarchiver.com/post/7143</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7143</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:55:41 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 11:55:16 GMT]]></title><description><![CDATA[<p dir="auto">have you checked your Shell Extensions Options in PA?</p>
]]></description><link>https://forums.powerarchiver.com/post/7142</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7142</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 11:47:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/klumy" aria-label="Profile: klumy">@<bdi>klumy</bdi></a>:</p>
<p dir="auto">works for me here</p>
<p dir="auto">have a look at my screenshot</p>
<p dir="auto">strange! this is what I get:</p>
<p dir="auto"><img src="http://greg79.altervista.org/img/PACompressInsteadOfExtracting.jpg" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">how can that be??</p>
]]></description><link>https://forums.powerarchiver.com/post/7141</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7141</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:47:58 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] a &quot;Check for self-extracting ZIP, ARJ..&quot; issue on Sat, 08 Jan 2005 11:25:29 GMT]]></title><description><![CDATA[<p dir="auto">works for me here</p>
<p dir="auto">have a look at my screenshot<br />
<img src="/uploads/_imported_attachments/attachment_p_2086_0_zwischenablage01.png" alt="attachment_p_2086_0_zwischenablage01.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/post/7138</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7138</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:25:29 GMT</pubDate></item></channel></rss>
