<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Current Folder in Extract dialog]]></title><description><![CDATA[<p dir="auto">It would be helpful if there would be a way to go directly to the current directory of the compressed file.</p>
<p dir="auto">Often enough a compressed file is already where it has to be uncompressed. But one needs to check the file first to see if it has directory/path names in it, and if not, one may want to create a New Folder first. So the Extract Here shell extension can’t always be used.</p>
<p dir="auto">If the Extract dialog would have an additional button or an extra line in the Extract to: pull down to go to the compressed file’s current directory, one can easily take it from there instead of needing to click several drives and folders to get there.</p>
<p dir="auto">I hope this hasn’t been requested before. I looked through the wishlist and couldn’t immediately find it.</p>
<p dir="auto">Kind regards</p>
<p dir="auto">Patrick</p>
]]></description><link>https://forums.powerarchiver.com/topic/430/current-folder-in-extract-dialog</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 08:18:32 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/430.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 02 Jan 2005 14:14:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Current Folder in Extract dialog on Sat, 08 Jan 2005 11:27:30 GMT]]></title><description><![CDATA[<p dir="auto">I support this s´wish ;)</p>
]]></description><link>https://forums.powerarchiver.com/post/7139</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7139</guid><dc:creator><![CDATA[klumy]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:27:30 GMT</pubDate></item><item><title><![CDATA[Reply to Current Folder in Extract dialog on Sat, 08 Jan 2005 11:22:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lpatrick" aria-label="Profile: lpatrick">@<bdi>lpatrick</bdi></a>:</p>
<p dir="auto">Yes and no.</p>
<p dir="auto">What you propose would indeed always work, but:</p>
<ul>
<li>if the archive already contained a folder (with that name or an other), you’d have two folders;</li>
<li>if the archive doesn’t containe a folder, one is limited to the name of the archive as the name for the folder and one may need to rename the folder later on.<br />
In each case, it would be a two step process, wouldn’t it?</li>
</ul>
<p dir="auto">Thank you for taking it into consideration.</p>
<p dir="auto">good points! I surely second your request!</p>
]]></description><link>https://forums.powerarchiver.com/post/7137</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7137</guid><dc:creator><![CDATA[manuangi]]></dc:creator><pubDate>Sat, 08 Jan 2005 11:22:43 GMT</pubDate></item><item><title><![CDATA[Reply to Current Folder in Extract dialog on Thu, 06 Jan 2005 19:29:09 GMT]]></title><description><![CDATA[<p dir="auto">Yes and no.</p>
<ul>
</ul>
]]></description><link>https://forums.powerarchiver.com/post/7127</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7127</guid><dc:creator><![CDATA[lpatrick]]></dc:creator><pubDate>Thu, 06 Jan 2005 19:29:09 GMT</pubDate></item><item><title><![CDATA[Reply to Current Folder in Extract dialog on Sun, 02 Jan 2005 18:08:51 GMT]]></title><description><![CDATA[<p dir="auto">I might have a good idea for it, thanks…<br />
As usual, you could use extract to filename/ as an easy solution to the problem</p>
]]></description><link>https://forums.powerarchiver.com/post/7105</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/7105</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Sun, 02 Jan 2005 18:08:51 GMT</pubDate></item></channel></rss>
