<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Device list bug]]></title><description><![CDATA[<p dir="auto">Version: v11.70.09</p>
<p dir="auto">If you keep pressing the “Refresh” bottom at this screen, then the drop down list will keep adding the same device. Not a big deal but rather a cosmetic issue.</p>
<p dir="auto"><img src="http://img709.imageshack.us/img709/1816/pabug.png" alt="" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forums.powerarchiver.com/topic/4281/device-list-bug</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 18:43:55 GMT</lastBuildDate><atom:link href="https://forums.powerarchiver.com/topic/4281.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 30 Dec 2010 16:30:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Device list bug on Fri, 31 Dec 2010 13:02:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lit2fly" aria-label="Profile: lit2fly">@<bdi>lit2fly</bdi></a>:</p>
<p dir="auto">Yes!! and Happy New Year to you ALL!!</p>
<p dir="auto">☆。★。☆。★<br />
。☆ 。☆。☆<br />
★。＼｜／。★<br />
Happy New Year!<br />
★。／｜＼。★<br />
。☆。 。☆。<br />
<em>☆。 ★。 ☆</em></p>
<p dir="auto">Happy New Years to you too!</p>
]]></description><link>https://forums.powerarchiver.com/post/24544</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24544</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 31 Dec 2010 13:02:02 GMT</pubDate></item><item><title><![CDATA[Reply to Device list bug on Fri, 31 Dec 2010 12:09:55 GMT]]></title><description><![CDATA[<p dir="auto">Yes!! and Happy New Year to you ALL!!</p>
。☆ 。☆。☆<br />
★。＼｜／。★<br />
★。／｜＼。★<br />
。☆。 。☆。<br />
]]></description><link>https://forums.powerarchiver.com/post/24543</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24543</guid><dc:creator><![CDATA[lit2fly]]></dc:creator><pubDate>Fri, 31 Dec 2010 12:09:55 GMT</pubDate></item><item><title><![CDATA[Reply to Device list bug on Fri, 31 Dec 2010 10:10:55 GMT]]></title><description><![CDATA[<p dir="auto">I got it, you have to press really really fast, like you are playing an game or something… we will see what we can do - for instance, disable that button until result comes back.</p>
]]></description><link>https://forums.powerarchiver.com/post/24536</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24536</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Fri, 31 Dec 2010 10:10:55 GMT</pubDate></item><item><title><![CDATA[Reply to Device list bug on Fri, 31 Dec 2010 04:19:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/spwolf" aria-label="Profile: spwolf">@<bdi>spwolf</bdi></a> yes, the device name in device manager is “PIONEER DVD-RW DVR-218L”. It also happens in all burner tools. For example:</p>
<p dir="auto"><img src="http://img502.imageshack.us/img502/44/84531268.png" alt="" class=" img-fluid img-markdown" /></p>
<p dir="auto">H: and G: are two virtual drivers installed by Daemon Tools, while I: is the Pioneer one.</p>
<p dir="auto">One point to note, you need to press the “Refresh” button really fast to re-produce the problem.</p>
<p dir="auto">Here is the video in action:<br />
<a href="http://img812.imageshack.us/img812/448/4gu.mp4" target="_blank" rel="noopener noreferrer nofollow ugc">http://img812.imageshack.us/img812/448/4gu.mp4</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/guido" aria-label="Profile: guido">@<bdi>guido</bdi></a> tried to change the driver letter (for the screen above I’ve changed the driver to I:, while my first post was F: ), doesn’t help.</p>
]]></description><link>https://forums.powerarchiver.com/post/24534</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24534</guid><dc:creator><![CDATA[lit2fly]]></dc:creator><pubDate>Fri, 31 Dec 2010 04:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to Device list bug on Thu, 30 Dec 2010 21:54:50 GMT]]></title><description><![CDATA[<p dir="auto">works fine on my pc. Did you try to give the dvd a new drive letter?</p>
]]></description><link>https://forums.powerarchiver.com/post/24531</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24531</guid><dc:creator><![CDATA[guido]]></dc:creator><pubDate>Thu, 30 Dec 2010 21:54:50 GMT</pubDate></item><item><title><![CDATA[Reply to Device list bug on Thu, 30 Dec 2010 19:40:36 GMT]]></title><description><![CDATA[<p dir="auto">is that Pioneer DVD-RW DVR-218? It seems to be device specific as it doesnt happen on my computer. Does it also happen in other PA Burner tools?</p>
<p dir="auto">thanks!</p>
]]></description><link>https://forums.powerarchiver.com/post/24530</link><guid isPermaLink="true">https://forums.powerarchiver.com/post/24530</guid><dc:creator><![CDATA[spwolf]]></dc:creator><pubDate>Thu, 30 Dec 2010 19:40:36 GMT</pubDate></item></channel></rss>
